What is it?
Ultradog MN
PostPosted: Fri Mar 21, 2014 12:39 pm    Post subject: What is it? Reply to specific post Reply with quote
A 4000 with British 6 bolt hubs. 3000 front, non PS, early tin - too early to be an SU right?
Maybe like one of my own - built out of pieces?
Here's another one that I wish were closer as I'd buy it for parts.
RickB
PostPosted: Fri Mar 21, 2014 1:03 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
Only things I see out of the ordinary for an early British 4000SU would be the Minnemec injection pump and dual elemant fuel filter assembly. Probably has had a 3000 engine transplant.
JMOR
PostPosted: Fri Mar 21, 2014 1:04 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
The pretty one has lower lift arms/links that sure look like they extend far to rear!
RickB
PostPosted: Fri Mar 21, 2014 1:05 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
Not sure I see $1000 in parts out of the second one.
Fordfarmer
PostPosted: Fri Mar 21, 2014 1:11 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
You're just going to have to borrow Ken's big trailer when you go get your 3000...
Fordfarmer
PostPosted: Fri Mar 21, 2014 1:12 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
I agree. I've seen a few 3000's with the Minnemec pump (owned one), but never a 4000.
Ultradog MN
PostPosted: Fri Mar 21, 2014 1:19 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
I thought they didn't come out with the SUs till about 1970 or so. I suppose they could have swapped tin.
RodinNS
PostPosted: Fri Mar 21, 2014 2:07 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
I dunno what it is... but it's certainly got the 3000 engine unless someone adapted a Simms pump onto the 201... I'd wager it's more mutt than the paint lets on.
Rod
RickB
PostPosted: Fri Mar 21, 2014 2:42 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
Nothing about that tractor says 1970.
Ultradog MN
PostPosted: Fri Mar 21, 2014 2:43 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
I agree Rick. But I thought that's when the SUs came out.
RickB
PostPosted: Fri Mar 21, 2014 3:17 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
I've got no input on the start of SU production.
Shetland Sheepdog
PostPosted: Fri Mar 21, 2014 4:30 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
I see the decal is still on the under side of the hood! Would be real interesting to compare that to the stamped numbers!
Sean in PA
PostPosted: Fri Mar 21, 2014 5:37 pm    Post subject: Re: What is it? Reply to specific post Reply with quote
If you search on 4000SU as the model number on the part site it comes back empty, but if you search on 4140 it comes back with "(4140) - 3 CYL SPECIAL UTILITY TRACTOR (1/65-12/74)" So New Holland thinks it was made starting in '65.
