MM UB
rmf1066
PostPosted: Fri Mar 21, 2014 1:58 pm    Post subject: MM UB Reply to specific post Reply with quote
It's me again with more questions about my UB. It's getting close to fire up and there is a couple of things that I'm having a hard time figuring out. First there are two lines on the left side of the block one that goes to the oil pressure gauge and the other one on a rectangular plate that I don't know where it goes or does. The other question is the tractors hyd pump was missing when I got it all it had was the spacer between the dis and pump with a oil line going to it. Can I take the spacer off and block off the line or do I need to put a cover on the spacer and keep the line. Thanks Ryan
mmfan55
PostPosted: Fri Mar 21, 2014 3:21 pm    Post subject: Re: MM UB Reply to specific post Reply with quote
the line from the block should be the oil pressure guage line. the other can be plugged ( in the cap). Put a plate over the hydraulic pump hole and keep the oil line. It puts oil onto the parts that runs your distributor. Not good if they are dry
53ZBU
PostPosted: Fri Mar 21, 2014 3:53 pm    Post subject: Re: MM UB Reply to specific post Reply with quote
The line in pic 1 on the plate is a vent/breather line goes to the top of the hyd reservoir under the front of the fuel tank,the other one I would personally plate where it is at and leave that line,just my opinion.
rmf1066
PostPosted: Fri Mar 21, 2014 4:03 pm    Post subject: Re: MM UB Reply to specific post Reply with quote
Thanks for all the help. This tractor was in pices when I picked it up and my first Moline. Thanks for all the help again!!! Ryan
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
