A few things to consider with WD power
Fairlydangerous
PostPosted: Fri Mar 21, 2014 8:41 pm    Post subject: A few things to consider with WD power Reply to specific post Reply with quote
I'm buying a WD45, I don't know which one yet but of which I've driven there are various issues to consider:
Synchros on the first tractor, or is it just the shift fork / linkage? It won't stay in third with anything on the gas, and it sticks into fourth pretty bad. I can't even hold it into third gear.
On the second tractor I have to hold on the hand clutch to drive anywhere.
The second tractor also has an engine from a WD in it that leaks from all edges.
Of less concern is that number 1's radiator has a big hole in it and 2 has a bucket on front with a junk hydraulic system, or the pump isn't working very well
JMS/.MN
PostPosted: Fri Mar 21, 2014 10:44 pm    Post subject: Re: A few things to consider with WD power Reply to specific post Reply with quote
I would suggest a learning curve.....WD45s were a generation before any synchros....that tractor is simply worn out. Holding the hand clutch in- maybe just some clutch adjustment with shims....unless they"re already worn out and removed. Leaky WD engine in a WD45? keep looking. Big differences in those two engines. Radiators can be repaired/replaced. Loader with junk hyd/pump not working? How do you judge that?
Randy Shoe
PostPosted: Sat Mar 22, 2014 12:00 am    Post subject: Re: A few things to consider with WD power Reply to specific post Reply with quote
I'm thinking also I would keep looking for a tractor that doesn't have so many problems that you described. You might be inheriting a lot of some ones problems and a big expense.
Lonnie Smith
PostPosted: Sat Mar 22, 2014 4:49 am    Post subject: Re: A few things to consider with WD power Reply to specific post Reply with quote
If they want more than scrap price for them, walk away. There are tons of WD45's out there that don't need $1000 worth of work before you can use them.
John Gottlied
PostPosted: Sat Mar 22, 2014 6:53 am    Post subject: Re: A few things to consider with WD power Reply to specific post Reply with quote
if you are looking for a WD45 , I have a good one just sitting
black
PostPosted: Sun Mar 23, 2014 6:29 am    Post subject: Re: A few things to consider with WD power Reply to specific post Reply with quote
I would just keeping lookink. There are some good deals on this site and honest guys . I bought my WD45 5 yeras ago for a G and changed the top or the trans.--- never looked back, she's a real good girl -- good luck
