Bore a 226 continental
Curt Courtney
PostPosted: Sun Mar 23, 2014 11:55 am    Post subject: Bore a 226 continental Reply to specific post Reply with quote
can you go to a 3.50 bore on a 226 continental and if so what would be good pistons and valves to use?
Dieseltech
PostPosted: Sun Mar 23, 2014 2:21 pm    Post subject: Re: Bore a 226 continental Reply to specific post Reply with quote
I would say no, I have a bad 226 block that I broke out the cylinder on purpose. The wall thickness on that one was about .110 inch thick. A 244 block is 3 7/16 like the 162. .060 over would be 3.4975, closer to what you want. Only problem is finding a 244 block, not as common as the 226.
Mike in Mn.
PostPosted: Mon Mar 24, 2014 5:49 pm    Post subject: Re: Bore a 226 continental Reply to specific post Reply with quote
A short story, about 25 years ago I resurrected a worn out 333 with a shot engine, made up my mind to put a flat head continental in it, found a 244 in an Oliver combine. There used to be a Continental Dealer in the Twin Cities, talked to the machinist there to see what I could do for max power and long life, I was going to use this tractor on the farm. He said stay away from the 244 cause they all cracked by the exhaust valves, said find a good 226 and he would bore it 40 over for me and it would live a good long life, put in hard seats and stellite valves and he said it would run 10,000 hours on propane. I took his advice and I still use that tractor today and have never touched the engine, many, many hours of use. I will also add, not a lot of power by todays standards and it will not lug down like a 4 cylinder will.
