135 Carb problems
ditch
PostPosted: Sun Mar 23, 2014 5:06 pm    Post subject: 135 Carb problems Reply to specific post Reply with quote
Just rebuilt the motor actually whole tractor. Tractor did run fine before rebuild lessthe knocking noise (reason for rebuid). Rebuilt the carb also. Tractor will run 3 or 4 mins then stalls i turn the swith off wait about a min then starts right back up. I have taken the carb off and apart and checked for trash several times and nothing. I have put the carb on manifold without fuel bowl turn fuel on and it dont seem to have enough fuel coming thru neddle and seat. i have taken fuel bowl out of tank checked for any blockage nothing there either. i have checked fuel line itself no blockage. Even removed gas cap while checking thought maybe not venting. One thing i did notice when i put carb back on tractor with fuel bowl empty i turn gas valve on and gas will slowly fill up the glass bowl and i mean slowly. but if i crack the fuel line at carb it fill quickly ,seems almost like a vapor lock ..could this be possible. sorry for the long post but i am stumped..and i know someone here has a answer ,thanks in advance
FBH44
PostPosted: Sun Mar 23, 2014 5:17 pm    Post subject: Re: 135 Carb problems Reply to specific post Reply with quote
Some carbs have a small hidden inlet screen, just inside the inlet pipe connection, could it be it never got cleaned out?
ditch
PostPosted: Sun Mar 23, 2014 5:26 pm    Post subject: Re: 135 Carb problems Reply to specific post Reply with quote
I have cleaned the carb to the point where i put a small wire thru every passage that i saw . One thing i did do is i removed the brass 90 with the screen that was attached to it and replace it with a regular brass 90 with a compression fitting. the reason i did this is because the guy i bought the tractor from just had a lot of tape on the fitting that didnt actually fit the brass 90 with the screen
Phil Tibbetts
PostPosted: Sun Mar 23, 2014 7:06 pm    Post subject: Re: 135 Carb problems Reply to specific post Reply with quote
I think your problem may be a piece of the tape is blocking your flow somewhere. That is one problem with Teflon tape. Whenever I use it I always stay 1 thread back from the end. Whenever you replace a fitting that had the tape there is almost always some trace of the tape left in the female thread. Hope this helps. I
ditch
PostPosted: Sun Mar 23, 2014 7:19 pm    Post subject: Re: 135 Carb problems Reply to specific post Reply with quote
Thanks Phil, I cleaned the carb out with small wire ,used brake cleaner, and compressed air. i have looked for any trash and cant find anything.
FBH44
PostPosted: Mon Mar 24, 2014 1:05 am    Post subject: Re: 135 Carb problems Reply to specific post Reply with quote
Well, one time I had a Farmall H that did that. Finally found that [ hate to addmit this ] I ovedid it to the point I used pipe dope on the sediment bowl threads going up into the gas tank. I had used somuch, I had it ooze out into the inlet of the bowl; had barely enough flow area. It would flow a little tiny bit, but blocked off flow for wide-open. Finally found it, removed the glob, all was well.
ditch
PostPosted: Mon Mar 24, 2014 4:39 am    Post subject: Re: 135 Carb problems Reply to specific post Reply with quote
all i used was a little bit of thread seal tape. but i am going to take it off again today and see whats going on. i will let you no my findings ,Thanks for all yalls help
ditch
PostPosted: Thu Mar 27, 2014 7:19 am    Post subject: Re: 135 Carb problems Reply to specific post Reply with quote
Little update on the carb issue. I took the little spring off of the needle that connects to the float,turned the gas valve on and the gas filled the glass bowl up quickly. thought i was onto something which i think i am. but the tractor still run out of gas within 2 or 3 mins of running.
