hat air compressor to buy?
Nick m
PostPosted: Mon Mar 24, 2014 2:22 pm    Post subject: hat air compressor to buy? Reply to specific post Reply with quote
I'm going to start painting my own tractors. What do you guys recommend size and brand wise? Figure I'll do one or two per year at the most. Don't want to break the bank but don't want harbor freight junk either. I've been down that road.
Nick m
PostPosted: Mon Mar 24, 2014 2:55 pm    Post subject: Re: hat air compressor to buy? Reply to specific post Reply with quote
Title was supposed to be; what air compressor to buy.
glennster
PostPosted: Mon Mar 24, 2014 3:15 pm    Post subject: Re: hat air compressor to buy? Reply to specific post Reply with quote
Quincy or champion. 5 hp 220 v single phase. Look for a 2 stage compressor pump, close to 20 cfm, and an 80 gallon tank. Uprights take up less room, they need to be bolted down good.
RandyB(MI)
PostPosted: Mon Mar 24, 2014 4:23 pm    Post subject: Re: hat air compressor to buy? Reply to specific post Reply with quote
I might also add Ingersol Rand but NOT the chain store models but IR,s own Industrial models with T-30 pump and Baldor motor. 5hp/220 1750 rpm / 2cyl/2stage/preferably the "V" configuration (like a Harley) w/80 gal tank. Not going to get a good one for $1000 though. I paid $1700 for mine in 1981 but made a living with it, sometimes running 2 DA,s all day long but also sandblaster and now retired but never had to do anything to it as far as repairs. Still has the original belts on it. You can leave the hose wide open and it will recover and shut off all while open hose! Parts are all still available but have never needed any? IR , Quincy , Saylor Beale,Champion. Saylor Beale is still made right here in MI.
Fordfarmer
PostPosted: Mon Mar 24, 2014 5:40 pm    Post subject: Re: hat air compressor to buy? Reply to specific post Reply with quote
I've got a C-Aire (sp?) 80 gallon, 2stage, 5 h.p. for my milking parlor. Only problem in 17 years of daily use has been one blown gasket between the head and line to the tank. Cast iron pump, Baldor motor. Made in Wyoming, MN.
dr sportster
PostPosted: Mon Mar 24, 2014 6:33 pm    Post subject: Re: hat air compressor to buy? Reply to specific post Reply with quote
Don't rule out Harbor Freight for a filter at the final hose connection point. Only because a made in USA is a few hundred and a H-F is about 25 bucks. Not everything in H-F is evel. Knevel.
RedJA
PostPosted: Mon Mar 24, 2014 6:57 pm    Post subject: Re: hat air compressor to buy? Reply to specific post Reply with quote
I have a craftsman 80 gal I've used for over ten years. They have a 30 gal for around 300 bucks which would be enough for painting.
Stephen Newell
PostPosted: Tue Mar 25, 2014 4:02 am    Post subject: Re: hat air compressor to buy? Reply to specific post Reply with quote
If you were continuously spraying the side of a barn you might need a pretty large compressor. Painting a tractor you are starting and stopping a lot so a small one would do fine. As long as you had a compressor that would deliver 4 scfm at 90 psi or larger you wouldn"t have a problem.
dboll
PostPosted: Tue Mar 25, 2014 5:38 am    Post subject: Re: hat air compressor to buy? Reply to specific post Reply with quote
I found an 80 gal. 325 Quincey on Craigslist for $400, works good and built better than most of the stuff made today.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
