Dents, Dimples, Dings Part 4, Just about done!
JRinElginTX
PostPosted: Mon Mar 24, 2014 9:23 pm    Post subject: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
Well she's about 98% done, but for the most part it's all ready to go. Just have a few touch ups, brake adjustment and it's ready to roll. Thanks again to everyone who helped me out in getting this put back together. Enjoy!
L.B,
PostPosted: Mon Mar 24, 2014 11:46 pm    Post subject: Re: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
Excellent job and The A I gave you last time you had pictures still stands very nice job. You need to put hose clamps on air tube at air cleaner and carburetor it takes 4 clamps. Somebody will tell you not to use rubber gas line, I use a combo of metal and rubber.After I get past the exhaust manifold with metal and start down toward the carb I put an inline filter and rubber and the last few inches are metal. The safest is all metal. Your call.
maxwell99
PostPosted: Tue Mar 25, 2014 3:14 am    Post subject: Re: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
Great job!
Note to file: the under axle stabilizer should have the pin directly across from the lower arm pin.
On my tractor the adjustable lift arm screw is on the right side, may not make a difference, check it out.
Again, looks good,
carlntexas
PostPosted: Tue Mar 25, 2014 5:34 am    Post subject: Re: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
I can see a lot of sweat going in to that looks good, but now you will be afraid to use it. Smile
Beanmedic
PostPosted: Tue Mar 25, 2014 6:23 am    Post subject: Re: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
Very nice! Lots of elbow grease went into that. But, it certainly paid off.
...and cute young'un!!
stansab
PostPosted: Tue Mar 25, 2014 8:21 am    Post subject: Re: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
good work nice to see another n saved good lookin little guy enjoy them both.
Colin King
PostPosted: Tue Mar 25, 2014 6:10 pm    Post subject: Re: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
You"ve done really nice work. Lots of attention to detail!
Colin, MN
Royse
PostPosted: Tue Mar 25, 2014 6:43 pm    Post subject: Re: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
Nice work!
I use a rubber line for testing, but I'm one of those safety
minded guys that would pick it out as a permanent solution.
A 30 inch piece of 1/4 inch brake line has the correct fittings
on each end. Just bend it and screw it in. Less than $5.
Then that cute little fella wouldn't worry about fire! Wink
I like the wire loom for protecting the wires.
I see in the one picture you had a new boot for the shifter too.
If you have trouble getting it on, boil it in a pan of water first.
That will soften it up so it will flex easier to go on.
Keep us posted, you've done a lot of work and it looks great!
01BIRDDOG
PostPosted: Wed Mar 26, 2014 9:22 am    Post subject: Re: Dents, Dimples, Dings Part 4, Just about done! Reply to specific post Reply with quote
I would say this is a beautiful job on your tractor......Will outlast you now with proper care.[/b]
