641-Interesting pump-prime remedy
jeff pk
PostPosted: Thu Apr 03, 2014 10:33 am    Post subject: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
My hydraulic pump was leaking oil from the gear/engine-drive connection, so I decided to remove the pump. PO failed to install any gasket there at all so it was an easy fix, but the prime was lost in the pump when it was reinstalled and on reading the archives I tried to fiddle with the pipe-plug on top and blow air into the dipstick hole---both of which only got the pump to judder the lift slowly up. The real fix came by jacking up the rear end high---so that it was above the front, and running it for awhile while I raised and lowered the lift---after about 10 minutes it was smooth as silk. Question: what's happening inside that's priming the pump?
Just curious...
sunbeam
PostPosted: Thu Apr 03, 2014 10:43 am    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
works almost every time I drive the front end into the road ditch and leave the back wheels on the road.
Dean
PostPosted: Thu Apr 03, 2014 11:01 am    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
Be advised that the shim gaskets between the hydraulic pump and the engine block are used to set drive gear backlash. Add/remove as necessary.
Dean
jeff pk
PostPosted: Thu Apr 03, 2014 11:34 am    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
I remember reading that. Should it ever be entirely free of a gasket?
Dean
PostPosted: Thu Apr 03, 2014 12:05 pm    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
I cannot imagine why. It will leak without.
Dean
mhb@ufe
PostPosted: Thu Apr 03, 2014 3:29 pm    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
As sunbeam said, driving the front end inti a dish is a common method. If you think about the oil level along a straight line toward the front of the tractor and that is how high the oil is in the suction tube. When you raise the back of the tractor the oil level raises at the front there for raising the oil level in the suction tube.
Mark
Larry NCKS
PostPosted: Thu Apr 03, 2014 5:03 pm    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
Hmm!!! Drive the front end inti a dish? Won't that break the dish??? Laughing Rolling Eyes
Sorry! Couldn't resist!
mhb@ufe
PostPosted: Thu Apr 03, 2014 5:38 pm    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
You have to use a Tupperware dish :-)
Mark
Larry NCKS
PostPosted: Fri Apr 04, 2014 2:28 am    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
Laughing
mhb@ufe
PostPosted: Fri Apr 04, 2014 4:22 pm    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
must have been thinking about food instead of tractors. Hope I didn't put my food in the ditch.
Mark
Hobo,NC
PostPosted: Fri Apr 04, 2014 6:44 pm    Post subject: Re: 641-Interesting pump-prime remedy Reply to specific post Reply with quote
Nutter head different thought "THUMBS UP"
