Massey Ferguson TO35 Point Melting
EvansFarm
PostPosted: Sat Apr 05, 2014 12:31 pm    Post subject: Massey Ferguson TO35 Point Melting Reply to specific post Reply with quote
The nylon bumper on the contact gap keeps melting. Someone has switched from generator to standard alternator. Wondering what the problem is?
garvas
PostPosted: Sat Apr 05, 2014 12:47 pm    Post subject: Re: Massey Ferguson TO35 Point Melting Reply to specific post Reply with quote
Possible 12 volt charging into a 6 volt system. I think the TO35 was a 6 volt system. If that is the case you will need to step the voltage down.
EvansFarm
PostPosted: Sat Apr 05, 2014 1:23 pm    Post subject: Re: Massey Ferguson TO35 Point Melting Reply to specific post Reply with quote
How do you do that?
Phil Tibbetts
PostPosted: Sat Apr 05, 2014 7:10 pm    Post subject: Re: Massey Ferguson TO35 Point Melting Reply to specific post Reply with quote
Put a ballast resistor in the line feeding the ignition coil.
Inno
PostPosted: Sat Apr 05, 2014 7:11 pm    Post subject: Re: Massey Ferguson TO35 Point Melting Reply to specific post Reply with quote
Some were 6V, positive ground, after 1955 they were 12V neg. ground (from the info I have). What year is the TO35 you have and how long ago was it converted to an alternator? If it was working fine and just started melting points, you have something else wrong. If it was a recent conversion you need to make sure everything is matching voltage wise.
More info would help.
ditch
PostPosted: Sun Apr 06, 2014 4:53 pm    Post subject: Re: Massey Ferguson TO35 Point Melting Reply to specific post Reply with quote
You can get one from your local auto parts store like NAPA. On a 12 volt system you only need around 8 volts going to a distributor with points. Mine is a 12 volt system i found a resistor with a Ohm value of 1.82 and it took the 12 volts down to a tad over 9 volts to the distributor which is ok.(higher the Ohm value the more it will drop the voltage) The resistor will go inline to the wire that is connected to the plus side of the coil. Food for thought if you convert the distibutor to HEI (electronic pick-up means no points) you want need a resistor because the electronic pick-up can take the 12 volts. Hope this helped
Richard L
PostPosted: Mon Apr 07, 2014 10:52 am    Post subject: Re: Massey Ferguson TO35 Point Melting Reply to specific post Reply with quote
The TO 35 changed to 12 v. at S/N 161250 in 55.
supergrumpy
PostPosted: Tue Apr 08, 2014 4:26 am    Post subject: Re: Massey Ferguson TO35 Point Melting Reply to specific post Reply with quote
if you are talking about the rubbing block on the ignition points, I had same problem, points gap kept closing up
I cleaned the dist cam and put just a tiny dab of grease on the lobes, problem solved
the friction was melting the plastic
