1950 8n jubilee
Dave carlson
PostPosted: Sun Apr 06, 2014 9:17 pm    Post subject: 1950 8n jubilee Reply to specific post Reply with quote
Getting water /liquid in oil bath air cleaner. Where is it coming
from? How do I fix it? No water / anti freeze getting in the
engine oil.
maxwell99
PostPosted: Sun Apr 06, 2014 11:16 pm    Post subject: Re: 1950 8n jubilee Reply to specific post Reply with quote
Does the tractor set outside?
If so, maybe rain is getting into the air intake hole, some part may be missing. Many old tractors never see the inside of a barn.
My old tractor has a rubber horn shaped air scoop that fits under the dash then across to the air cleaner. The hood protect it from rain water.
Has someone washed the tractor and maybe got water up in this area with a pressure hose?
How often do you have to check the oil bath for water contaminantation.
This could be a very serious problem if you were to suck water into a hot engine.
Finding the water leak should be a top priority.
Let us know what you find, or post pictures of your air cleaner.
Charles Krammin
PostPosted: Mon Apr 07, 2014 4:26 am    Post subject: Re: 1950 8n jubilee Reply to specific post Reply with quote
Running tractor in winter, causes condensation in cold oil.
Charles Krammin SW MI
Bruce (VA)
PostPosted: Mon Apr 07, 2014 4:54 am    Post subject: Re: 1950 8n jubilee Reply to specific post Reply with quote
Dopes your tractor look like the ones in the picture? Those are 1950 8N's. A Jubilee has an overhead valve engine, made in 1953.
Chances are the water is from condensation. But do check the gasket.
75 Tips
Nick167
PostPosted: Mon Apr 07, 2014 5:36 pm    Post subject: Re: 1950 8n jubilee Reply to specific post Reply with quote
Bruce I noticed the john Deere tractor in the cyclone precleaner my granpa put jd in his cyxlone after he restored it
Bob
PostPosted: Tue Apr 08, 2014 2:05 pm    Post subject: Re: 1950 8n jubilee Reply to specific post Reply with quote
Dave, To make solving any future problems more clear, you can clarify what tractor you have, by surfing over to the "ID" section of John Smith's most excellent Ford tractor website...
Smiths IDENTIFY
Dave carlson
PostPosted: Tue Apr 08, 2014 4:18 pm    Post subject: Re: 1950 8n jubilee Reply to specific post Reply with quote
Thank you all for your insight and help. Yes, the Jubilee is a 1953 but i will check the id numbers to be sure. Thanks especially Maxwell99 and Bruce. You all have given good insight and i will be back with the next chapter after i get out with the Jubilee again next week. i will follow up on the thoughts you gave.
Dave
