hydraulic pump
Jerry Livingston
PostPosted: Sat Apr 19, 2014 7:43 pm    Post subject: hydraulic pump Reply to specific post Reply with quote
I have a piston pump on 850 and it sound's like gear that run's off flywheel is making noise. Doe's that mean need to rebuild pump? Or replace gear.If need to rebuild best place to buy kit? plus seen poeple say order from CNH what doe's that stand for?
JMOR
PostPosted: Sat Apr 19, 2014 7:49 pm    Post subject: Re: hydraulic pump Reply to specific post Reply with quote
Jerry Livingston wrote:
(quoted from post at 23:43:07 04/19/14) I have a piston pump on 850 and it sound's like gear that run's off flywheel is making noise. Doe's that mean need to rebuild pump? Or replace gear.If need to rebuild best place to buy kit? plus seen poeple say order from CNH what doe's that stand for?
There is no pump gear running off the flywheel.
cbrown9064
PostPosted: Sat Apr 19, 2014 8:03 pm    Post subject: Re: hydraulic pump Reply to specific post Reply with quote
CNH stands for Case- New Holland, the successor of Ford tractors...
Pump runs off internal gear not flywheel.
Jerry Livingston
PostPosted: Sat Apr 19, 2014 8:19 pm    Post subject: Re: hydraulic pump Reply to specific post Reply with quote
So is that gear getting bad? What would be the noise that i hear?
GVSII
PostPosted: Sun Apr 20, 2014 5:06 am    Post subject: Re: hydraulic pump Reply to specific post Reply with quote
(quoted from post at 20:43:07 04/19/14) I have a piston pump on 850 and it sound's like gear that run's off flywheel is making noise. Doe's that mean need to rebuild pump? Or replace gear.If need to rebuild best place to buy kit? plus seen poeple say order from CNH what doe's that stand for?
The pump is driven by a gear on the back end of the camshaft.If the pump is noisey it could be something as simple as needing a thicker or thinner gasket between the pump and where it mounts on the engine.But it could be a noisey pump or one of the gears(pump or camshaft gear) going bad or loose.Could also be timeing gears on the way out.
JAL1012
PostPosted: Sun Apr 20, 2014 9:10 am    Post subject: Re: hydraulic pump Reply to specific post Reply with quote
The motor was completely overhauled just about 1yr ago. I will take pump off check gear it wasn"t making noise when i put pump on same time motor was rebuild"t. It just started 2week"s ago.
