4000
Bob Pruitt
PostPosted: Sun Apr 20, 2014 6:00 am    Post subject: 4000 Reply to specific post Reply with quote
I have a gas fueled 4000 that has a, what appears to be, 5 bolt inspection plate on the bottom of the hydraulic res. What is this and what is it"s function? It"s leaking and needs to be repaired.
Dean
PostPosted: Sun Apr 20, 2014 8:49 am    Post subject: Re: 4000 Reply to specific post Reply with quote
The following discussion asumes that you have a four cylinder 4000 with five speed transmission. Ignore otherwise.
The plate held in place by 5 bolts is an access cover for the relief valve and also a good place to clean accumulated sediment.
If you remove it be advised that there is also an alignment dowell to contend with.
Bite the bullet and buy a proper gasket from CNH for it. DO NOT use ANY goop.
Dean
Bob Pruitt
PostPosted: Sun Apr 20, 2014 12:12 pm    Post subject: Re: 4000 Reply to specific post Reply with quote
Dean, thanks very much I will follow your advice...
shaun wallace
PostPosted: Sun Apr 20, 2014 2:37 pm    Post subject: Re: 4000 Reply to specific post Reply with quote
That dowel has oringon it. Plugs drilling for hyd tube.
