PostPosted: Mon Apr 21, 2014 1:02 pm    Post subject: 656 Reply to specific post Reply with quote
Hi everyone. Thought I would try this again. I
posted yesterday and was hoping everyone was busy
with Easter and didn't have time to answer. A
couple three weeks ago I posted a question
concerning the 3-point. We kind thought the
unloading valve was faulty. I took the valve apart
and replaced the o-rings in the valve. I had some
time on Saturday so decided to put her back
together. It still does not work like it should.
It will work when you use the auxiliary valve. It
also works without the aux. valve when you goose
the motor. It will also work by moving draft
control lever up and down with the normal lever
about midway on the selector. I need some
suggestions. Could the valve be sticking? Any
feedback would be appreciated. I know there is a
lot of knowledge out there. Hopefully someone has
seen this problem before. Thanks Doug
bob ia
PostPosted: Mon Apr 21, 2014 1:12 pm    Post subject: Re: 656 Reply to specific post Reply with quote
had same deal mech said mixing valve ws by passing cleaned it but still have to do like you. I just learned to get by as this guy is respected. If loader won't raise I just check it
