John Deere 300x
Bill Tankersley
PostPosted: Tue Apr 22, 2014 3:10 pm    Post subject: John Deere 300x Reply to specific post Reply with quote
engine cranks, no fire to plugs. What could the problem be?
rrobert
PostPosted: Wed Apr 23, 2014 4:59 am    Post subject: Re: John Deere 300x Reply to specific post Reply with quote
Try testing with a new plug. I had JD do that. The customer ran the engine with the choke on and ruined the plugs. New plugs and it ran fine after I retrained him on how to use the choke.
Next, would be to check the "trigger" if it is a Kawasaki engine.
If Briggs or Tecumseh engine, check with kill wire disconnected. If still has condensor, check points and condensor. Could be bad magnetto(coil).
If Kohler engine, check points and coil.
Bill Tankersley
PostPosted: Wed Apr 23, 2014 4:12 pm    Post subject: Re: John Deere 300x Reply to specific post Reply with quote
Rrobert
The tractor is John Deere X300 with a kawasaki There is no spark at the plug wires .engine # FH661
What are the trigger? where are they on the engine
Bill Tankersley
rrobert
PostPosted: Fri Apr 25, 2014 7:53 am    Post subject: Re: John Deere 300x Reply to specific post Reply with quote
Should be a small thin sqaure box on opposite side of engine of carb.
I do not know how to test it. They can be pricey if guessing that is the issue.
I would pull the shroud first and make sure a mouse didn't chew wire or leave a nest on top of sparkplug wire. Then, I would try that box.
The one below is for a motorcycle but looks similar to the mower module. The mower module/trigger might have 2 or 3 wires.
motorcycle module/trigger.
