Author |
Message |
cjackman Regular
Posted: Thu Apr 24, 2014 2:44 pm Post subject: 930 pto |
Went to adjust my pto clutch pack per specs. My service manual shows two pins. One would be locked the other not. I understand how to adjust, but only see one pin on the collar and it was locked. So, am I missing one or is that how it is? |
Back to top |
Bradiniowa Regular
Posted: Thu Apr 24, 2014 5:06 pm Post subject: Re: 930 pto |
Did you turn pto looking for the other one? Just did my 730. I &at shop manuals are hard to follow in my opinion. Nothing like hands on experience and buddy that can advise you. |
Back to top |
cjackman Regular
Posted: Thu Apr 24, 2014 6:08 pm Post subject: Re: 930 pto |
I turned it but was bumping the engine over and it was just me so could have missed it. I got a genuine original CASE service manual so pretty detailed. I'm gonna try again with some help after work tonight. |
Back to top |
oldabe30 Regular
Posted: Fri Apr 25, 2014 2:58 am Post subject: Re: 930 pto |
One pin. |
Back to top |
cjackman Regular
Posted: Fri Apr 25, 2014 5:04 am Post subject: Re: 930 pto |
Yep,one pin. Think I got it. Man unless your an 80 pound gymnast,it's a squeeze getting in there lol. |
Back to top |
nanuk Regular
Posted: Sat May 17, 2014 5:37 pm Post subject: Re: 930 pto |
I have a 930CK "64 6sp
mine has two pins. There are three sides to the collar, two have pins, one has nothing.
I remove the plate, using needle nose pliers, I pull the pin by caming against the housing, and twist the PTO shaft with my hand CCW to tighten.
When I hear the click of the other pin dropping in, I rotate the shaft until I can feel the other pin.
remember which way you turned to go from one to the other, and then reverse it each time. (I talk out loud to myself to help me remember)
taking the plate off/on takes longer than adjusting |
Back to top |
