Oliver 88
Row Crop
PostPosted: Wed Apr 30, 2014 1:49 pm    Post subject: Oliver 88 Reply to specific post Reply with quote
I bought an old Oliver 88 from a guy down in Indiana a few years back. I just got it running again. It doesn't have a serial number tag on it, so I don't know what year it is. The number 190320 is stamped on the engine, with K100c just below it. Is that enough to go by in finding the year?
rrlund
PostPosted: Wed Apr 30, 2014 2:05 pm    Post subject: Re: Oliver 88 Reply to specific post Reply with quote
There's a casting code on the bottom of the rear end,that'll tell when the casting was poured at least.
Don't remember right now if it's month/day/year or day/month/year.
Row Crop
PostPosted: Wed Apr 30, 2014 3:03 pm    Post subject: Re: Oliver 88 Reply to specific post Reply with quote
Oh. Thank you!
J. S. -2
PostPosted: Wed Apr 30, 2014 5:18 pm    Post subject: Re: Oliver 88 Reply to specific post Reply with quote
On that block there are small differences as well as in te rest of the tractor. Does it have 4 bolt pad by the distribtor for a Hobbs hour meter? Where did you look for the serial number tag as that changed laterin 1952. does it have a hydraulic unit?
Row Crop
PostPosted: Thu May 01, 2014 1:41 am    Post subject: Re: Oliver 88 Reply to specific post Reply with quote
It doesn't have an hour meter place. It does have hydraulics, but it doesn't have a ridge on the frame just under the side panels, so I'm guessing 51-54.
J. W. S.-2
PostPosted: Thu May 01, 2014 11:05 am    Post subject: Re: Oliver 88 Reply to specific post Reply with quote
It was made before the spring of 52. If it has disk brakes pull the cover off and see if there is a nut inside the center of the bull pinion gear.
