Changing hydraulic oil on a 1650
CenTex Farmall
PostPosted: Wed Apr 30, 2014 7:49 pm    Post subject: Changing hydraulic oil on a 1650 Reply to specific post Reply with quote
Question on hydraulic oil change on a 1650. I know it has to be pumped out, but does it matter if I use one of the remote lines or should I use one of the ports on the hydraulic unit?
Also, is the PTO unit lubricated with gear oil from the trans or does it use hydraulic oil?
Rustytractorguy
PostPosted: Wed Apr 30, 2014 8:23 pm    Post subject: Re: Changing hydraulic oil on a 1650 Reply to specific post Reply with quote
We have used a remote on our 2-70.
Kell
PostPosted: Wed Apr 30, 2014 9:05 pm    Post subject: Re: Changing hydraulic oil on a 1650 Reply to specific post Reply with quote
PTO is lubed from transmission.
rrlund
PostPosted: Thu May 01, 2014 5:29 am    Post subject: Re: Changing hydraulic oil on a 1650 Reply to specific post Reply with quote
You could buy one of those little pumps that go on an electric drill,drop a small hose in the fill hole and suck it out that way.
Chief 83
PostPosted: Thu May 01, 2014 5:28 pm    Post subject: Re: Changing hydraulic oil on a 1650 Reply to specific post Reply with quote
Just changed mine in a
1550. I used the port on the side as per the manual. Plastic barbed fitting and about 4' of cheap vinyl hose. Worked great, better than expected. Only ran the tractor for maybe 2 minutes. I do think a hyd outlet would work.
