inner rim surface
Carl Marchese
PostPosted: Wed May 07, 2014 2:52 pm    Post subject: inner rim surface Reply to specific post Reply with quote
How can I resurface the inner rim so my tube does not deflate. Is there a rubber mat that can be applied?
Dr.Bert
PostPosted: Wed May 07, 2014 3:57 pm    Post subject: Re: inner rim surface Reply to specific post Reply with quote
Carl: I use a rotary wire brush on the inner surfaces and then paint heavily with a rust resistant paint. Also, one could cut up an auto inner tube and place in in the rim.
Den N Ms
PostPosted: Wed May 07, 2014 5:34 pm    Post subject: Re: inner rim surface Reply to specific post Reply with quote
Carl,You could coat it with rubberized under coating,but that will take 2 or 3 days to dry enough to put a tube against it.Better yet is to use black truck bed liner,it drys fast and works good.I have used both on several rims that I have redone.
Royse
They do make liners, but as Doc said old inner tubes work.
So does a couple layers of duct tape wrapped around the rim.
I too would clean out all the rust and prime then paint first.
I've used Rustoleum Rusty Metal primer with good results.
I brush it on, no need for it to look like a show car in there.
David in GA
PostPosted: Thu May 08, 2014 6:18 am    Post subject: Re: inner rim surface Reply to specific post Reply with quote
I had the same problem with the hat wheels. I sandblasted then primed, next a coat of spray undercoating and finished off with a layer of Gorilla tape. This made a surface that should not damage the tubes.
souNdguy
PostPosted: Thu May 08, 2014 3:12 pm    Post subject: Re: inner rim surface Reply to specific post Reply with quote
cleant he rim. grind, wire wheel, etc. prime with rust comtrol primer and then paint with rust control paint. epoxy paint works good too. if very rough.. boot it with an old tube.
i have seen some people use rubberized undercoating or bedliner paint with no friction addative added too.
tesmith66
PostPosted: Fri May 09, 2014 2:17 am    Post subject: Re: inner rim surface Reply to specific post Reply with quote
Duct tape: The handyman's secret weapon.
