3020 hyd. pump
lee little
PostPosted: Sat Jun 07, 2014 10:42 am    Post subject: 3020 hyd. pump Reply to specific post Reply with quote
It looks like I am going to have to break down and pull the hyd. pump on my 3020 because of a major leak. My shop manual says to pull the front end and go from the bottom. I have been told that the fuel tank can be pulled and work from the top.What are your thoughts/opinions/experiences on this? Thanks for any help on this, the knowledge on this board always amazes me. Thanks Lee
David G
PostPosted: Sat Jun 07, 2014 10:51 am    Post subject: Re: 3020 hyd. pump Reply to specific post Reply with quote
I believe the best solution is from the bottom.
tim s
PostPosted: Sat Jun 07, 2014 11:56 am    Post subject: Re: 3020 hyd. pump Reply to specific post Reply with quote
Take it out the bottom, remove all the lines including the one on top, take the frame loose at the engine and with a little help and a 4ft 2X4 let it down out..
lee little
PostPosted: Sat Jun 07, 2014 3:31 pm    Post subject: Re: 3020 hyd. pump Reply to specific post Reply with quote
Thanks guys I appreciate the help. I guess out the bottom it will go as soon as time and space allow. Lee
buickanddeere
PostPosted: Sun Jun 08, 2014 5:33 am    Post subject: Re: 3020 hyd. pump Reply to specific post Reply with quote
The 3020 used the 2000 series pump in either the 40cm/2.4cu" or 50cm/3.0cu" sized.
There is a bolt in swap to the 65cm/4cu" 2000 series pump optional in the 4000,4020,4320,4520,4620,4230,4430,4630,4040,4240,4440,4640 etc
lee little
PostPosted: Sun Jun 08, 2014 6:15 am    Post subject: Re: 3020 hyd. pump Reply to specific post Reply with quote
Thanks for the info! Lee
