Tractor show and mag problem
HenryO
PostPosted: Tue Jun 10, 2014 5:57 am    Post subject: Tractor show and mag problem Reply to specific post Reply with quote
The will be a tractor show Friday 13 thru Sun 15 at Medina Co. Fairgrounds in Medina Ohio. Club sponsored. Also Auction at 4:00 PM on Friday. Now spomeone please refresh me on timing a mag. This is for my Cub which has given me much consternation. I las timed a mag 12 years ago and for the life of me (82) I cant remember how. Thanks
AlanA
PostPosted: Tue Jun 10, 2014 7:55 am    Post subject: Re: Tractor show and mag problem Reply to specific post Reply with quote
HenryO wrote:
(quoted from post at 14:57:08 06/10/14) The will be a tractor show Friday 13 thru Sun 15 at Medina Co. Fairgrounds in Medina Ohio. Club sponsored. Also Auction at 4:00 PM on Friday. Now spomeone please refresh me on timing a mag. This is for my Cub which has given me much consternation. I las timed a mag 12 years ago and for the life of me (82) I cant remember how. Thanks
UNPLUG COIL WIRE FROM DIST. CAP. Don't want it to fire while you do this.
Timing mark on pulley should line up just as #1 Cyl is at top of compression stroke. (remove spark plug and put your thumb over the hole to find compression stroke).
Loosen bolts holding mag, and turn the top of it toward block.
Turn engine with crank until timing mark is again at TDC. Rotate mag away from engine block until impulse coupling clicks, then tighten the bolts in that spot.
HenryO
PostPosted: Tue Jun 10, 2014 8:44 am    Post subject: Re: Tractor show and mag problem Reply to specific post Reply with quote
Thanks AlanA. It comes back npow. Thanks again Henry
HenryO
PostPosted: Tue Jun 10, 2014 4:09 pm    Post subject: Re: Tractor show and mag problem Reply to specific post Reply with quote
Thanks again. Everything is now right
rhtx55
PostPosted: Thu Jun 12, 2014 3:15 pm    Post subject: Re: Tractor show and mag problem Reply to specific post Reply with quote
If and when you are at a show, tractor ride or parade............. if ANYONE is watching you crank it over it absolutely will not start, no matter how much cranking you do.
It will flood, cough, sputter & back fire till the cows come home, but wil not start !!
Just as soon as it gets dark, or everyone walks away and you are all alone, it will start on the first quarter turn & purr like a kitten..........
