Ether starting
Stew Nelson
PostPosted: Fri Jun 20, 2014 8:05 am    Post subject: Ether starting Reply to specific post Reply with quote
I have a AC 6080 that I've had for about 3 months. I have to use ether to start it even on a hot day. Is there an easy fix. When it runs it does not smoke.
Dieseltech
PostPosted: Fri Jun 20, 2014 9:10 am    Post subject: Re: Ether starting Reply to specific post Reply with quote
How many hours is on the pump, if high hours the head/rotor assembly may have internal groove wear that will cause too much internal leakage at cranking speed. Does it smoke on acceleration?
Bob Bancroft
PostPosted: Sat Jun 21, 2014 1:32 pm    Post subject: Re: Ether starting Reply to specific post Reply with quote
Depends on your definition of hot. It was normal for the earlier 6060's and 6080's to require a whiff of starting fluid on anything cooler than a hot day. I suppose if your engine is tired all these years later it may need help even on a "hot" day. They upped the compression in later ones, and it helped a lot. Hopefully any overhaul kits out there are the later style. But if it runs OK, just keep going.
