installing sb chevy in H
Goto page 1, 2  Next
Marti in mo
PostPosted: Tue Jul 08, 2014 9:50 am    Post subject: installing sb chevy in H Reply to specific post Reply with quote
I have this urge to put a small block in an h I have and make a parade tractor or tractor ride tractor out of it. question is there a kit or plans to do this, im curious and thought I would ask on here if anyone knows please post. Thanks for any help Marti
rustyfarmall
PostPosted: Tue Jul 08, 2014 10:05 am    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
Marti in Mo wrote:
(quoted from post at 10:50:08 07/08/14) I have this urge to put a small block in an h I have and make a parade tractor or tractor ride tractor out of it. question is there a kit or plans to do this, im curious and thought I would ask on here if anyone knows please post. Thanks for any help Marti
I don't think the frame rails on an H are wide enough to accept a Chevy without doing some serious modifications. Several Ms I know of have a Chevy in them, but I don't think there is a "kit" for them.
High Octane
PostPosted: Tue Jul 08, 2014 3:29 pm    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
mite fit, if you used 350 frame rails, or 460 framerails. you may need to use a 4 speed bellhousing and bolt that to the Hs engine plate, extend the driveshaft out, and make it use a chevy clutch spline.
i tried it once, H bell just wasnt wide enuff to put the block closer back like they do in the M. oil filter n starter wouldnt fit either, so thats why i mentioned the 460 rails. wider, longer, and bolts right up to H bell. hope this helps.
Allan in NE
PostPosted: Tue Jul 08, 2014 4:10 pm    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
I put a 350 on an irrigation well once. You'll be soooooo disappointed in it as it will be so darned lame. Promise.
Eye candy and that's all.
Allan
DeltaRed
PostPosted: Tue Jul 08, 2014 5:02 pm    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
I'm with Allen. "Eye candy".It wont have any 'power' unless you wind 'er up tight.Dont know about a "kit",but there are 1000s of cases where someone has repowered an H or M(or any other tractor make/model).But it will look cool with twin stacks.......I recently(last winter) put a 2.8L Ford V6 in an F12.Looks cool,but wont pull the sled as far as an 'original' F12.Might have something to dpo with the 14.9x26 combine tires....
D Slater
PostPosted: Tue Jul 08, 2014 5:14 pm    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
This one was feathered in farm show mag.
Buzzman72
PostPosted: Tue Jul 08, 2014 5:46 pm    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
Saw an H with a Chevy 2.8 V6 in it. What made it work was the fact that the owner had pulled the belly pump out, and in the front of the tractor transmission had installed a 4-speed from an early S-10 with a bolt holding the shift rail in second gear...which happened to be right at a 2:1 gear ratio.
So the torque of the engine at the flywheel was doubled, and the ground speed more closely matched ground speed of the original H, as far as up through 3000-3400 rpm was concerned.
Might look into that...if you can find the right diameter clutch disc and spline count to make that work.
CenTex Farmall
PostPosted: Tue Jul 08, 2014 7:36 pm    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
An old GMC V6 would look cool and haven't seen one of those done. That was 60 degree motor and had a deep skirt block.
David G
PostPosted: Tue Jul 08, 2014 9:11 pm    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
I agree, the GMC V6 is the perfect engine, just gotta find one.
Redturbo
PostPosted: Tue Jul 08, 2014 9:50 pm    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
Not a H, its some sort of V-12 gmc gas engine. Saw it @ RPRU.
[img][/img]
[img][/img]
Buzzman72
PostPosted: Wed Jul 09, 2014 12:28 am    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
Back in the '60's, GMC got the idea to combine TWO
351 cubic inch V6's into a single block...this is
the result.
702 Cubic Inch V12
David R Inman
PostPosted: Wed Jul 09, 2014 3:21 am    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
Not a H, but our work in progress Super M (M grill) with an IHC V8.
What we are doing is bolt a spacer between the V8 flywheel and the M, so that we can use the M starter. Similar may work with a smaller motor and an H. Good to know a freindly machenist if your going to do such.
ryanwheelock
PostPosted: Wed Jul 09, 2014 7:48 am    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
Looks tough with the 2 stacks going up!!! Like that you used an IH motor too.
ryanwheelock
PostPosted: Wed Jul 09, 2014 7:52 am    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
There is no "kit" for that like rusty said.
dej(Jed)
PostPosted: Wed Jul 09, 2014 10:40 am    Post subject: Re: installing sb chevy in H Reply to specific post Reply with quote
Here is my F20. It has both the Chevy and Farmall tranys. 327 has plenty of power for whatever you want to do. It is all about gear selection.
Goto page 1, 2  Next
Page 1 of 2
