straw walker blocks
DNW in MI
PostPosted: Tue Jul 15, 2014 6:32 pm    Post subject: straw walker blocks Reply to specific post Reply with quote
I would like to kmow what other have done when the crank is worn and new blocks won't tight up cranks. It's a white 7300 combine.
Charles Krammin
PostPosted: Wed Jul 16, 2014 3:13 am    Post subject: Re: straw walker blocks Reply to specific post Reply with quote
Are they maple blocks? On a JD 45 they had spacers to take out to adjust. try Miking the shaft and then cutting that amount off the face of one half. Not perfectly round that way.
To get perfectly round would have to shave more off face and rebore to worn crank throw size.
Charles Krammin SW MI
oliverkid
PostPosted: Wed Jul 16, 2014 11:47 am    Post subject: Re: straw walker blocks Reply to specific post Reply with quote
Like charles said. Outside of a new walker crank, you will have to modify the blocks to fit the wear on the shaft.
DNW in MI
PostPosted: Wed Jul 16, 2014 3:22 pm    Post subject: Re: straw walker blocks Reply to specific post Reply with quote
So just cutting half of the blocks will work? Thought about cutting both blocks but seemed you would have an egg shape hole. Yes malpe blocks
j hikemper
PostPosted: Thu Jul 17, 2014 5:58 am    Post subject: Re: straw walker blocks Reply to specific post Reply with quote
bought a set from agco for my 750 massey that they had on the shelf ,, pricey ,, son Michael looked them over and made me an entire set out of seasoned white oak, he loves tinkering in wood... after 2 seasons ,they are holding up fine ,, but .. they should be hard maple
oliverkid
PostPosted: Fri Jul 18, 2014 2:27 pm    Post subject: Re: straw walker blocks Reply to specific post Reply with quote
You may want to shave both halves and re bore the blocks to the worn diameter of the crank.
Bob
PostPosted: Fri Jul 18, 2014 3:14 pm    Post subject: Re: straw walker blocks Reply to specific post Reply with quote
I have found this thread INTERESTING, because, in my experience, the "throws" on the walker cranks wear terribly "out of round", and, even if you modify the wood blocks to have smaller holes, just the "high sides" of the "egg-shaped" crank throw will contact the blocks, leaving a lot of "play" 90ยบ from there and allowing the walker bearings/shaft to hammer, knock, and ultimately crack and break the walkers.
Years back, I had that happen twice, once with a high-houred 503 IH and then with a used and abused 7700 DEERE. Wound up replacing the cranks, and a couple of walkers in both.
IMHO, this might work if this is a machine used for "play" but if you are going to use it and work it and put some hours on it, new, or good used cranks are the only "fix".
Good luck!
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
