Super Major transmission issue.
JLMac
PostPosted: Sun Jun 04, 2017 4:30 pm    Post subject: Super Major transmission issue. Reply to specific post Reply with quote
I got this tractor last November and change all fluids. The transmission oil was 2-3 inches low and very dark. This spring after only few hours of run time including maybe 15 kilometers of road trips I changed the oil and found filings.
From info from Fordson sites I decided to haul her home and split, concerned about upper shaft bearings.
Got her split.
The lock nut on primary transmission upper shaft is stripped. I assume the woodruff key should lock the retainer. Could the woodruff break? The main transmission upper shaft bearing was missing one bearing holder, not sure what its called. All missing roller bearings in trans bottom.
Curious why the nut stripped. The woodruff key was not near the retainer, could it have broke. Sorry forgot to take picture of woodruff key before taking out (destroying).
Any advice on this would be greatly appreciated! Thanks Jeff
JLMac
PostPosted: Sat Dec 09, 2017 3:15 pm    Post subject: Re: Super Major transmission issue. Reply to specific post Reply with quote
I've been on 6 day week work since I did the split but have managed to make some progress. Had a new nut made and reassembled it with permanent loctite.
JLMac
PostPosted: Sat Dec 09, 2017 3:46 pm    Post subject: Re: Super Major transmission issue. Reply to specific post Reply with quote
2 of the clutch spring retainer stems were broke.
I used snowmobile head studs I had to repair them.
JLMac
PostPosted: Fri Dec 15, 2017 4:06 pm    Post subject: Re: Super Major transmission issue. Reply to specific post Reply with quote
Got her back together, I changed the pto and transmission seals except for the small transmission input shaft seal. No leaks after a few around the block trips and it shifted good, quite a relieve.
Next I drove it 20 km out to my brothers acreage were I store it. It worked great, no leaks and transmission/rear end oil levels did not change Cool . Hope to get back to restoring it next summer.
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
