Care for wood deck
Goto page 1, 2  Next
redgreen
PostPosted: Mon Jun 26, 2017 9:15 am    Post subject: Care for wood deck Reply to specific post Reply with quote
I just bought a new trailer and wondered what everyone recommended to care for the wood? I've read linseed oil, used motor oil, and some people say leave it be.
Thanks in advance!
jon f mn
PostPosted: Mon Jun 26, 2017 10:09 am    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
Let it age for a year, then on a hot sunny
day soak it with used motor oil.
View user's profile AIM Address
rustyfarmall
PostPosted: Mon Jun 26, 2017 10:46 am    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
CVPost-Jon f mn wrote:
(quoted from post at 11:09:52 06/26/17) Let it age for a year, then on a hot sunny
Exactly! Repeat at least once per year.
D beatty
PostPosted: Mon Jun 26, 2017 5:30 pm    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
I also let mine set one season and then soaked it with used motor oil. i also tarp mine in the winter.
kcm.MN
PostPosted: Mon Jun 26, 2017 7:40 pm    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
First things first - did you buy treated or untreated wood? If treated, you need to let the wood dry well before applying a sealer. You don't HAVE to, but the wood will last much longer if you reapply the sealer every year or two.
If you got untreated, then you need to seal it ASAP, before rain hits it. Personally, I like any kind of used petroleum oil, including the synthetic stuff - anything except vegetable-based oils. 2nd on my list would be a good deck sealer, but for the use, I think used oil works best.
Also, I use untreated, as we don't have "them" kinda bugs up here, and the oil works great at treating the less-costly untreated wood. For initial application, I apply until it won't accept any more, then every month or two will apply a 2nd and 3rd coat, again, until it won't accept any more. Then will be good for a year or two.
BarnyardEngineering
PostPosted: Wed Jun 28, 2017 6:12 am    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
How do you get the edges, end grain, and undersides of the boards? When you slop oil on the deck it only kinda gets on the top, and dribbles down the sides some, but doesn't get underneath.
kcm.MN
PostPosted: Wed Jun 28, 2017 11:27 am    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
I remove the boards when treating. Process is the same whether you use oil, water sealer, stain or paint. Any part of the wood that you leave exposed will only shorten its useful life.
The reason I prefer oil is, it is an excellent moisture barrier. It also helps stop any bugs from getting into the wood. And, woodpeckers hate the stuff! Water sealers work well but are spendy. Look nicer than oil though. Stain works well, but again there's the price. And don't even waste your time with paint. Many people think that paint "waterproofs" wood. That couldn't be further from the truth. Paint will retard the passing of moisture, but moisture still gets through. So, I simply prefer oil. Also used to use it a lot on beds of fire ants back in Texas, although that's frowned upon now.
The newer trailers I've seen, the boards are screwed in place. Some, like a PJ trailer I had recently, the screws were on top. Others are screwed in from the underside, which is better. My old lowboy tandem axle, which is 25+ years old, didn't even come with chains for securing it to the tow vehicle. Was no such thing as electric brakes back then on such a trailer, and I once towed a TO-30 with rotary mower from Dallas almost to Houston using my little Dodge Ram-50 (built by Mitsubishi) truck - with 2.0L engine, no less! Anyway, this older trailer, you have to pry up under the middle of each board and, preferably with a helper, add 2-by's under the board, then pry up a little high and add another 2-by, until one end of the board comes out from under the steel lips that hold them in place. No screws used anywhere. The original treated wood decking lasted about 10 years, and I never treated it at all. Then the trailer sat for another 10 years never getting used, so the boards rotted away. So up here, I chose to use untreated lumber and apply oil, and simply could not be happier!! I was afraid the wood would be slippery, but I don't use it enough to have to walk on it shortly after applying the oil. By the time I need it again, the oil has soaked in good and is doing its job, and the deck traction is good in any weather.....EXCEPT ice! Wink
Oh, when I replaced the boards some years back, I used lumber that I had laying around. Only 1 or 2 full-length 16' boards, so had to splice some together from underneath. Also had some 2x6 of that "plastic" lumber that I got from an auction. So about 1/3 of the decking is that stuff, which needs no treatment. Kinda interested to see which lasts longer, but I'm betting it'll be the oil-treated wood - provided I keep maintaining it. As for the plastic lumber, went to price it recently and 1) can't hardly find the 2-by thickness anymore (is special order around here) and GEEZ, has it ever gotten crazy expensive!!
...By the way, once the boards are full-treated on all sides (2 or 3 times to saturation that first year), will no longer be a need to treat anything but the top side. Can get the edges with a small paint or foam brush, but bottom isn't exposed to the elements, and that's what does the most harm. So it's only during that first treating season that the boards will need to be removed 2 or 3 times for treatment. Otherwise, just recoat from topside.
D beatty
PostPosted: Wed Jun 28, 2017 9:48 pm    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
I leave gap between boards and soaked with oil from top and works great and over time it soaks all they way around.I have 2 hay racks that
are over 40 years old and have been soaked with oil and still good. On the PJ trailer I soak it and make sure that screw holes are full of
oil.
J.Wondergem
PostPosted: Sat Jul 01, 2017 3:29 pm    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
I also use motor oil every year. Just don't let anyone that you like sit on it. LOL.
showcrop
PostPosted: Sat Jul 01, 2017 3:31 pm    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
This subject is on the monthly schedule. Do a search and you will get a few hundred sure fire methods.
Stephen Newell
PostPosted: Thu Aug 03, 2017 7:53 pm    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
The new trailer is sure to be decked with untreated wood so it will need something. If it were me I would use a deck finish.
kcm.MN
PostPosted: Fri Aug 04, 2017 12:13 am    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
Last time I went shopping for a trailer (about 2-3 years ago), the decking on PJ trailers used treated. I thought that was standard, across the board.
rustyfarmall
PostPosted: Fri Aug 04, 2017 4:13 am    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
kcm.MN wrote:
(quoted from post at 01:13:31 08/04/17) Last time I went shopping for a trailer (about 2-3 years ago), the decking on PJ trailers used treated. I thought that was standard, across the board.
Yes. Pressure treated lumber is standard across the board.
D beatty
PostPosted: Fri Aug 04, 2017 7:31 am    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
My trailer came 6 years ago with treated lumber but I still soak it with oil draining.
vsteel
PostPosted: Fri Aug 04, 2017 10:09 am    Post subject: Re: Care for wood deck Reply to specific post Reply with quote
When I bought my trailer, the person I bought it from said he used to work at a paint store and the best thing he found for taking care of wood is TWP 100. It is what I use and it is doing a great job.
https://www.twpstain.com/twp-100-series
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
