Farmall 230 securing locations
Goto page Previous  1, 2
caterpillar guy
PostPosted: Wed Aug 30, 2017 2:01 am    Post subject: Re: Farmall 230 securing locations Reply to specific post Reply with quote
First off that is basically like an A,C,Cub you can break the blcok corners off pulling to hard on it. Just like if it is stuck. So I would put a bracket on the sides that has a piece across the front then with a plate with a hole you can use a shackle to chain to. Then for the back use a chain to the cross bar in the fast hitch or go up into the center under the hitch and tie in. Nobody will notice if the paint has a scratch unless they lie down there to look at something. Tieing through the wheels has kind of sharp edges for a strap and could result in a cracked or broke casting. Also if you don't get up some on the casting it can rock back and forth. I've seen it happen going down the road and in driveways.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
Page 2 of 2
