WC Allis
bwillett
PostPosted: Sun Sep 24, 2017 1:28 pm    Post subject: WC Allis Reply to specific post Reply with quote
That hard starting 1936 WC b=now won't run unless the choke is fully closed...Help
Ted in NE-OH
PostPosted: Sun Sep 24, 2017 4:07 pm    Post subject: Re: WC Allis Reply to specific post Reply with quote
Starving for gas. Fuel restriction in tank, outlet,line or in carb. Probably junk in bottom of tank.
bwillett
PostPosted: Mon Sep 25, 2017 2:28 am    Post subject: Re: WC Allis Reply to specific post Reply with quote
Thanks for your reply. Good places to start the adventure.
old
PostPosted: Mon Sep 25, 2017 7:30 am    Post subject: Re: WC Allis Reply to specific post Reply with quote
I would start by pulling the carb drain plug and make sure you have a good steady flow of gas that will fill a pint jar in under 3 minutes. If you have that at the drain plug you carb needs to be rebuilt/cleaned up. If you do not have that then work your way back to find where the flow gets slowed down. If you cannot find a flow problem then the float maybe sticking
bwillett
PostPosted: Thu Sep 28, 2017 4:10 pm    Post subject: Re: WC Allis Reply to specific post Reply with quote
Gonna try that next time I go out to where the tractor is stored....
bwillett
PostPosted: Sun Oct 08, 2017 1:32 pm    Post subject: Re: WC Allis Reply to specific post Reply with quote
Finally got out to the farm, today....tested the flow, and it is real good...Took the carb off and brought it home. The float has gas in it, but I can't tell how it got in, not a damp spot on it. It has been brazed a couple of times, tho'. The float needle seems to be okay.there is a lot of play in the throttle shaft...
tractorguy2
PostPosted: Sun Oct 08, 2017 4:47 pm    Post subject: Re: WC Allis Reply to specific post Reply with quote
I would replace the float. If it's been repaired several times. The extra solder makes it too heavy.
If you shop the online parts houses. You should be able to find a kit with a new throttle shaft. If you need bushings you can make your own from K&S brass tubing available from many hobby shops.
bwillett
PostPosted: Fri Nov 24, 2017 2:52 pm    Post subject: Re: WC Allis Reply to specific post Reply with quote
To finish the story. I bought a used carburetor from a man that parts Allis tractors, and a rebuild kit from another vendor. I had my local mechanic rebuild it. He had to make the throttle shaft, because none could be found. He bushed the carburetor body, cleaned it thoroughly, reassembled it, and gave it back to me last Wednesday, I put it on the tractor this afternoon, and after about 8 cranks, it started and ran beautifully. I went up and down the road (about a mile), shut the tractor off with the kill switch, and restarted the tractor on the 3rd crank. Then I shut it off by shutting off the gas and letting it run dry....I am really happy.....
bwillett
PostPosted: Fri Nov 24, 2017 5:32 pm    Post subject: Re: WC Allis Reply to specific post Reply with quote
CVPost-bwillett wrote:
(quoted from post at 15:52:39 11/24/17) To finish the story. I bought a used carburetor from a man that parts Allis tractors, and a rebuild kit from another vendor. I had my local mechanic rebuild it. He had to make the throttle shaft, because none could be found. He bushed the carburetor body, cleaned it thoroughly, reassembled it, and gave it back to me last Wednesday, I put it on the tractor this afternoon, and after about 8 cranks, it started and ran beautifully. I went up and down the road (about a mile), shut the tractor off with the kill switch, and restarted the tractor on the 3rd crank. Then I shut it off by shutting off the gas and letting it run dry....I am really happy.....
bwillett
PostPosted: Fri Nov 24, 2017 5:35 pm    Post subject: Re: WC Allis Reply to specific post Reply with quote
Just to go in a little deeper, the man that rebuilt my carburetor said that both jets were clogged......
Will Herring
PostPosted: Sat Nov 25, 2017 9:57 pm    Post subject: Re: WC Allis Reply to specific post Reply with quote
Good to know it was carb related. I had a lot of carb problems on one of my WDs, but ultimately found it was a rusty gas tank that was causing my woes. So if your problem reoccurs one of these days, you may need to look further upstream.
