WD45 bolt into WC
wilson ind
PostPosted: Fri Nov 03, 2017 10:08 am    Post subject: WD45 bolt into WC Reply to specific post Reply with quote
Have old WC. Engine is junk. Will WD or WD45 bolt in? Looking for any running engine that will fit.
old
PostPosted: Fri Nov 03, 2017 10:45 am    Post subject: Re: WD45 bolt into WC Reply to specific post Reply with quote
WD engine is the exact same engine as the WC engine. The WD45 will also bolt right on with no problems plus will give you a bit more HP
Aaron SEIA
PostPosted: Fri Nov 03, 2017 11:45 am    Post subject: Re: WD45 bolt into WC Reply to specific post Reply with quote
Either one is a direct bolt for bolt swap.
AaronSEIA
BushogPapa
PostPosted: Fri Nov 03, 2017 12:28 pm    Post subject: Re: WD45 bolt into WC Reply to specific post Reply with quote
The WD-45 had a stronger lower PTO gearbox casting..
JMS/.MN
PostPosted: Fri Nov 03, 2017 6:36 pm    Post subject: Re: WD45 bolt into WC Reply to specific post Reply with quote
WC and WD were 201 cu in engines....WD45 was a 226, all will bolt in. So will a D17,or Model E Gleaner combine, with some mods.
Joe(TX)
PostPosted: Tue Nov 21, 2017 4:39 pm    Post subject: Re: WD45 bolt into WC Reply to specific post Reply with quote
The pto housing has nothing to do with the engine swap.
