TO35 Fuel Tank
Goto page Previous  1, 2
steve19438
PostPosted: Tue Nov 07, 2017 1:38 pm    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
did not know a to-35 had a fuel gauge ?????????????????? none of mine do or provision for one.
Steve@Advance
PostPosted: Tue Nov 07, 2017 2:52 pm    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
They all have a gauge.
Provided by nature, called a stick! LOL
steve19438
PostPosted: Wed Nov 08, 2017 5:15 am    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
I use the same sticks that I block the clutches with.
Dieseltech
PostPosted: Wed Nov 08, 2017 5:30 am    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
The Ferguson wrench works well too.
oldmisterbill
PostPosted: Sun Nov 19, 2017 9:35 am    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
The "old tank" or "The sitting tank not used for a while" seem to always find some kind
or other crud,scale or what ever. I have a sheet of very fine copper mesh,much like the
little piece found near the top of some sediment bowls. Any way, off to
to get a wooden dowel the size of the PU tube(usually brass -easy to solder to) I
carefully made a peice of screen,wrapped around the PU tube =soldered the screen tube with
an electric soldering gun.Next I worked a little of the screen tubeover the fuel
pickup,soldered the screen to the tube. Now I have a filter of sorts to keep any larger
peices out of the fuel line. I make them as long as I can- more surface area. I forget how
the Fergusin PU is made but I have 3 of these on my case tractors. They help a lot in the
long run over the years. I am gettig more & more disable now, so they sit a lot. The good
is o fuel problems. Also I bought somemine 12 volt solinoid valves that I installed in
line - when I turn the key off the fuel is automaticly shut off also. My 2 bits.
Ron(Ont)
PostPosted: Sun Nov 19, 2017 9:48 am    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
CVPost-oldmisterbill wrote:
(quoted from post at 10:35:51 11/19/17) The "old tank" or "The sitting tank not used for a while" seem to always find some kind
Do you have any photos of the screen and solenoid?
Charles in Aus.
PostPosted: Mon Nov 20, 2017 11:47 pm    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
I fitted a fuel shut off solenoid to my elderly friend's TEA Ron . He was forever forgetting to shut the fuel off and once lost the entire tank onto the garage floor .
One that is used for petrol/LPG change overs is what you need .
LPG , Liquefied Petroleum Gas , is used as an alternative fuel a lot here , you start on petrol then change over to gas once hot . They cost about $28 and can be wired to either open or shut when energised . In this way you can wire it to open when the ignition is turned on , it will then automatically turn itself to the off position when the ignition is turned off .
https://www.ebay.com.au/itm/PETROL-FUEL-SOLENOID-SHUT-OFF-VALVE-12V-AUTOGAS-LPG-LIQUID-DIESEL/162727308877?hash=item25e34dae4d:g:uBQAAOSwOgdYnb5B
Ron(Ont)
PostPosted: Tue Nov 21, 2017 5:26 am    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
Charles in Aus. wrote:
(quoted from post at 00:47:43 11/21/17)
Wher did you mount it Charles? Do you have a photo? Smile
Charles in Aus.
PostPosted: Tue Nov 21, 2017 9:58 pm    Post subject: Re: TO35 Fuel Tank Reply to specific post Reply with quote
Sent you an e mail Ron .
Page 2 of 2
