D4H Fuel Pressures
Goto page Previous  1, 2
dpendzic
PostPosted: Mon Nov 27, 2017 9:09 am    Post subject: Re: D4H Fuel Pressures Reply to specific post Reply with quote
did you check for a filter screen in the supply fitting on the transfer pump? you have to disconnect the fuel line, then disconnect the angle fitting from the transfer pump and the filter should be in there--your transfer pump looks identical to mine---and also make sure that your fuel tank cap is venting correctly.
RodinNS
PostPosted: Mon Nov 27, 2017 9:24 am    Post subject: Re: D4H Fuel Pressures Reply to specific post Reply with quote
You need an 11/16" wrench and take that adapter right out, elbow and all, right back to the shell of the transfer pump. This is a common
problem when you get some algae in the tank... and until you get the tank clean, you will get quite accustomed to removing this screen. It's
a lot easier if you remove the side shield unless you have stubby wrenches.
Rod
N00bie
PostPosted: Mon Nov 27, 2017 3:21 pm    Post subject: Re: D4H Fuel Pressures Reply to specific post Reply with quote
You folks are wonderful!!!
If this was some sort of club I would donate to it.
I would have never known about that ity-bity screen in there if you folks would not have told me about it and explained exactly where it was.
Cleaned it out and the beast fired right up and hummed right along.
Cannot thank you folks enough.
Thank you
Rod (That my name, not referring to RodinNS but am thanking him as well)
Page 2 of 2
