Ferguson T20
Goto page 1, 2  Next
Cornishjon84
PostPosted: Sat Nov 25, 2017 10:08 am    Post subject: Ferguson T20 Reply to specific post Reply with quote
Hi I've just purchased a ferguson t20. I'm
having trouble identifying the model. Also
the approx age.
I'll post below a pic of engine numbers and
casting number on right hand side rear as
your sat on the tractor
Cornishjon84
PostPosted: Sat Nov 25, 2017 10:08 am    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
For some reason the bottom 2 engine numbers are upside down
Cornishjon84
PostPosted: Sat Nov 25, 2017 10:10 am    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
Only the photo
Cornishjon84
PostPosted: Sat Nov 25, 2017 10:30 am    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
If it's any help it's a 6 volt model and has the alluminium transmission housing
Bruce(OR)
PostPosted: Sat Nov 25, 2017 1:31 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
you should have a plate under the steering wheel with the serial # on it. hard stamped, TE or TO or some such then a hand stamped serial number. That initial number gives you the model and the serial number gives you the year.
Tom H.
PostPosted: Sat Nov 25, 2017 1:32 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
Well it is a TEA20, just don't know if it is the 80 or 85 engine. Is there a plate on the dash?
Ron(Ont)
PostPosted: Sat Nov 25, 2017 2:20 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
CVPost-Tom h. wrote:
(quoted from post at 14:32:56 11/25/17) Well it is a TEA20, just don't know if it is the 80 or 85 engine. Is there a plate on the dash?
If it is a 1950 TEA engine. It s an 80 mm if has not been modified.
Cornishjon84
PostPosted: Sat Nov 25, 2017 4:58 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
No plate on dash
Cornishjon84
PostPosted: Sat Nov 25, 2017 4:59 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
Hi thanks for your help. But there is no plate on the dash area
Cornishjon84
PostPosted: Sat Nov 25, 2017 5:00 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
Thanks for your help
Ron(Ont)
PostPosted: Sat Nov 25, 2017 6:50 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
Ron(Ont) wrote:
(quoted from post at 15:20:52 11/25/17)
There is another casting date behind the generator. If the water pump is attached to the block, it is an 80 mm. If the water pump is on the head, with a plate covering the old pump spot, it is an 85 mm.
Bruce(OR)
PostPosted: Sat Nov 25, 2017 7:29 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
You said aluminum transmission and I suspected a TEA. I believe that aluminum is actually magnesium.
Others here with vast more knowledge should be chiming in shortly. . .
Tony in Mass.
PostPosted: Mon Nov 27, 2017 6:11 am    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
First of May 1950? or Jan 5th? I forgot. The tag says 'exchange'??? So a replacement engine? With 80mm rather than newer 85mm parts? ... and has 'Triumph' on the tag... wonder when that started? Could this engine been intended for a Triumph car?
BTW, many years ago I was told by a former junk man from Cheshire, all the alloy castings in a fergie were from a yard in Merseyside full of scrapped WW2 aircraft.
Charles in Aus.
PostPosted: Mon Nov 27, 2017 1:58 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
May 1950 you are right Tony .
The plate is most likely denoting a factory rebuilt engine . The alloy is called 'Electron' and is an amalgam of aluminium and manganese , flammable at high temperatures and easily corroded if water enters the gearbox.
Cornishjon84
PostPosted: Mon Nov 27, 2017 2:07 pm    Post subject: Re: Ferguson T20 Reply to specific post Reply with quote
Very interesting! Thanks everyone for
taking time to reply it's very much
appreciated
Goto page 1, 2  Next
Page 1 of 2
