Allis Chalmers DD Motorgrader
Blanco
PostPosted: Tue Nov 28, 2017 8:30 am    Post subject: Allis Chalmers DD Motorgrader Reply to specific post Reply with quote
I would like to install a hot water cooling system cab heater on my DD grader with 262 Diesel engine. I have initially connected to pipe threat outlet in the middle of the top fast cooling system casting between the valve cover and the exhaust manifold.
I have connected into lower coolant drain plug on left side of block with second hose. I am lead to believe that a connection must be made closer to the water pump, however I am not sure of the correct location. I want to make sure I am not bypassing the function of the thermostat. The unit number is 1575 , and has the cast wishbone line from the radiator to the water pump.
I appreciate the insight.
