1020 hydraulic issues
Goto page Previous  1, 2, 3
mb1020
PostPosted: Sun Dec 03, 2017 9:39 am    Post subject: Re: 1020 hydraulic issues Reply to specific post Reply with quote
Ok I think I may have just stumbled on something but I need someone to confirm this.
Sorry again for the pics, they are upside down. i tried turning them on my computer, even turned them upside down, but they still upload wrong...oh well.
These are pics of the parts tractor with brake and steel oil lines removed. Am I correct that the line from the oil cooler attaches to the outermost (passenger/right side) hole which feeds directly into the brake cavity(reservoir?)? If so then my mechanic swapped the lines and the pump is probably drawing from the brake.
The innermost connection being the output from the trans pump to the hydraulic pump?
gene g
PostPosted: Sun Dec 03, 2017 8:58 pm    Post subject: Re: 1020 hydraulic issues Reply to specific post Reply with quote
The reason I ask is because I had a remanufactured valve do the one way creep and I found the problem in the lower part of the housing . Im sorry I cant give the exact
detail on the repair . I do not remember its been several years ago . I remember that I had to remove the entire valve to find the problem and make the repair . I was
not happy with the DO OVER when it was a mistake at remanufacture . I hate old age . I will look at some of my books tomorrow and see if will jog some old details .
gene g
PostPosted: Tue Dec 05, 2017 7:17 am    Post subject: Re: 1020 hydraulic issues Reply to specific post Reply with quote
I dont know which line goes where . But some small utility tractors had a check ball in one line . A parts book would answer what models used the check ball
mb1020
PostPosted: Tue Dec 05, 2017 2:52 pm    Post subject: Re: 1020 hydraulic issues Reply to specific post Reply with quote
CVPost-gene g wrote:
(quoted from post at 12:17:51 12/05/17) I dont know which line goes where . But some small utility tractors had a check ball in one line . A parts book would answer what models used the check ball
Yes the line going to the pump has a check valve.
gene g
PostPosted: Fri Dec 08, 2017 7:12 am    Post subject: Re: 1020 hydraulic issues Reply to specific post Reply with quote
Some times you can see a mark on the end of the lines at the trans. end where the keeper was holding them into the case .
Page 3 of 3
