Hf welder
Goto page 1, 2  Next
SVcummins
PostPosted: Wed Nov 29, 2017 6:47 pm    Post subject: Hf welder Reply to specific post Reply with quote
Anybody use one of these welders ?
https://www.harborfreight.com/90-amp-flux-welder-
61849.html
Steve@Advance
PostPosted: Wed Nov 29, 2017 6:58 pm    Post subject: Re: Hf welder Reply to specific post Reply with quote
Yes, POS!
It's AC. Pops and smokes, globs on what some might call a weld.
Under perfect conditions and practice, it will weld, but aint pretty.
SVcummins
PostPosted: Wed Nov 29, 2017 7:03 pm    Post subject: Re: Hf welder Reply to specific post Reply with quote
That?s what I was afraid of . Guess I?ll have to save up for a welder that uses gas with wire
Stroby
PostPosted: Wed Nov 29, 2017 7:11 pm    Post subject: Re: Hf welder Reply to specific post Reply with quote
Steve. HF is now offering a 125 amp unit, wonder if it works any better?
Ted in NE-OH
PostPosted: Wed Nov 29, 2017 7:27 pm    Post subject: Re: Hf welder Reply to specific post Reply with quote
The 125 amp model works good no complaints
DrCharles
PostPosted: Wed Nov 29, 2017 7:43 pm    Post subject: Re: Hf welder Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 22:03:42 11/29/17) That?s what I was afraid of . Guess I?ll have to save up for a welder that uses gas with wire
I would recommend that approach... after messing around for years with cheapies I never could get to work right, I finally bought a "refurbished" (direct from Hobart) Handler 140. It looked brand new to me, and even a new one isn't that expensive, and I found I could actually weld stuff! Cool
Stan in Oly, WA
PostPosted: Wed Nov 29, 2017 9:43 pm    Post subject: Re: Hf welder Reply to specific post Reply with quote
SVcummins; don't feel bad about it. You'll benefit from and enjoy the quality of a good welder for as long as you own it. If you buy a low quality welder like that one, you won't remember the few hundred dollars you saved for very long, but you'll be stuck with a shoddy piece of equipment that underperforms and makes welding more difficult for you for as long as you keep it. I believe that low quality welders discourage people. Some people never get a chance to see that they could be decent at welding if they had better equipment, and some people give it up altogether. People think that they'll trying welding with low quality, low cost equipment and if they like it, they'll buy better equipment. There are two problems with this: First, low quality equipment can be so difficult to use, or have so many problems that it makes it hard to like the process, so you never get to see that it can be not only fairly easy, but also gratifying and enjoyable. Second, most people have trouble spending good money after bad; it's hard to write off a mistake, take the loss and try to do better the next time.
One other small point to keep in mind, you can't MIG weld with a flux core only welder, but can run flux core on any MIG welder.
Stan
coshoo
PostPosted: Thu Nov 30, 2017 12:43 am    Post subject: Re: Hf welder Reply to specific post Reply with quote
I've never seen anyone who liked welding with flux core. I've got a MIG with solid wire and gas, and am OK at welding with it. Friend got a flux core, and neither one of us could ever get a decent weld out of it.
Texasmark1
PostPosted: Thu Nov 30, 2017 5:22 am    Post subject: Re: Hf welder Reply to specific post Reply with quote
I don't have one but assume what I saw in a HF catalog is similar to the TSC Farmhand 85. For light duty with .030 wire it has worked for me when used within it's capabilities.
Bret4207
PostPosted: Thu Nov 30, 2017 5:37 am    Post subject: Re: Hf welder Reply to specific post Reply with quote
I've burnt quite a bit of flux core simply because I don't have a big CO2 bottle. It's okay for rough work on lighter metals. I still use the stick for heavy stuff. Solid core and gas can make a nice weld, but I haven't quite got the hang of that yet. I'm proof you can have solid core and gas and still bubble gum stuff up! Laughing
Stan in Oly, WA
PostPosted: Thu Nov 30, 2017 12:15 pm    Post subject: Re: Hf welder Reply to specific post Reply with quote
Bret4207; There are a lot more things that can go wrong with the performance of a MIG welder than people generally acknowledge. I was in charge of a metal arts workshop at the local community college for a few years, and one of the things I had to spend a lot of time doing was troubleshooting the MIG welders and getting them going again. They were high quality Miller welders, not too many years old, but of course they were used every day by students in the college's welding program, so they saw a lot of hard use. If you own a good MIG welder, and you get all the settings right, and you don't have to ever change a setting, and nobody else ever uses it, and you recognize every problem that can degrade performance and correct it immediately, and you spend as much time practicing to improve your technique as you had to spend to become reasonably good with stick, then you might, MIGHT, be able to just pick it up and weld with it whenever you need to. That's why I always chose to stick weld unless I had no choice but to use MIG. I'll bet there were few people in the college's welding program who had put more 16 gauge metal together with stick than I had.
Stan
Bret4207
PostPosted: Fri Dec 01, 2017 4:46 am    Post subject: Re: Hf welder Reply to specific post Reply with quote
Stan, I've only got 20-25 hours on the MIG unit. I'm still trying to deal with not really being able to see the arc like I can with stick. Finally got an adjustable shade helmet and that helps. Remembering my glasses helps too! Getting the right amperage and wire feed speed is kinda tricky for me.
BobReeves
PostPosted: Fri Dec 01, 2017 10:57 am    Post subject: Re: Hf welder Reply to specific post Reply with quote
CVPost-coshoo wrote:
(quoted from post at 01:43:33 11/30/17) I've never seen anyone who liked welding with flux core. I've got a MIG with solid wire and gas, and am OK at welding with it. Friend got a flux core, and neither one of us could ever get a decent weld out of it.
Well now you know at least one... I have a Lincoln 175 and have never ran anything but flux core. Ya it splatters but cleans up OK and I have made welds that look and hold as good as any I have seen with gas.
Stan in Oly, WA
PostPosted: Fri Dec 01, 2017 11:29 am    Post subject: Re: Hf welder Reply to specific post Reply with quote
Bret; it's in your favor that you can see the arc when you're stick welding. My experience with students who were learning MIG welding and had no previous experience with any form of arc welding---and many of them were retired people, not kids---was that some people's eyes were just too sensitive for them to ever really be comfortable with the process. If you have to use shade 11 or higher before the arc isn't blinding to you when you're stick welding in the 100 amp range (or the MIG equivalent of that), it's going to be very difficult for you to see the work. Your description makes it sound like your problem is with the nozzle getting in the way so that you can't watch the puddle, but this is a problem you can solve. Not being able to view the arc unless your eye protection is turned so dark that you can't see anything else may not be possible to solve. At the risk of suggesting something that you've already tried, I'd say that finding a better position might help. There isn't much you can do about the angle of the MIG nozzle or the distance relative to the work because those are things you need to be able to change for different situations. But you might be able to position yourself differently in relation to the work, or vice versa, to bring it into view. Students would sometimes complain to me that they couldn't see the arc or the weld puddle no matter how they moved the work, but what they meant was that they hadn't been able to find a successful way to turn the work piece while leaving it on the table at the welding station while they continued to sit in the chair there. I'd ask them if they had considered standing up and bending over the work to get a better view, or had they considered putting it on the floor so they could work on it from any side. Sometimes it made a lot of difference.
Stan
Bret4207
PostPosted: Sat Dec 02, 2017 5:43 am    Post subject: Re: Hf welder Reply to specific post Reply with quote
Thanks Stan! I'm figuring it out slowly. I think a lot of it my failing eye sight. Have to find a set of glasses that focus right at the 1-3 foot area I need. Tried bifocals and about drove me nuts...or more nuts!
Goto page 1, 2  Next
Page 1 of 2
