6.0 Coolant leak
showcrop
PostPosted: Thu Nov 30, 2017 4:05 pm    Post subject: 6.0 Coolant leak Reply to specific post Reply with quote
My '06 6.0 has recently developed a coolant leak. It doesn't appear to leak while running, it doesn't leak while it is cooling down or right after shutting off, like you would expect. I can't see any place that is leaking, except that from the little puddle it is on the right side just behind the radiator. It appears to leak approx 4 oz. and it does not have to het even to operating temp to do it. It leaked a day or two ago, the day after having sat idling for maybe 6-8 minutes, then parked back inside. It doesn't leak while running or just after running, not until 12 hours later. The reservoir has lost about an inch of coolant.
Destroked 450
PostPosted: Thu Nov 30, 2017 6:10 pm    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
Probably a cold water leak, seems to be more common on diesel trucks but I've seen it on a few, normally around a hose fitting.
Check the hose clamps on the bottom of the radiator.
Don't know why but nearly every truck we had with 3406 Cat engines would get a cold water leak at the top radiator hose and thermostat housing.
Only did it during cold weather, hence why we called it a cold water leak.
hd6gtom
PostPosted: Thu Nov 30, 2017 11:31 pm    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
Are you asking about a ford diesel or a GM gas???
showcrop
PostPosted: Fri Dec 01, 2017 4:36 am    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
CVPost-hd6gtom wrote:
(quoted from post at 00:31:17 12/01/17) Are you asking about a ford diesel or a GM gas???
It is a Ford diesel. I have searched all around underneath and can see no place that it came from. No drops anywhere.
Destroked 450
PostPosted: Fri Dec 01, 2017 7:17 am    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
On the days it leaks are the temps colder?
ON the right side you have the bottom rad hose, rad fill hose, heater return line and I'm not sure what else.
Can't help you much, when I purchased my 04 the 6.0 had blown up, pulled the 6.0 and swapped in a 5.9 Cummins.
Bob
PostPosted: Fri Dec 01, 2017 8:06 am    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
GOOGLE "6.0 EGR cooler leak".
showcrop
PostPosted: Fri Dec 01, 2017 9:58 am    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
CVPost-Bob wrote:
(quoted from post at 09:06:54 12/01/17) GOOGLE "6.0 EGR cooler leak".
Thanks, Bob. I will pull the EGR and take a look as it said in one of the articles. I hope that it is not the cooler, it has only around 15,000 miles on it.
molinegb
PostPosted: Sat Dec 02, 2017 4:41 am    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
If EGR issue would be puking white out exhaust.
ASEguy
PostPosted: Mon Dec 18, 2017 3:24 am    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
Some coolants have dye in them. If your doesn't, put some dye in it and pressure test it or run it sitting still then shut it off and start looking. We use yellow glasses and a blacklight to aid in locating the dye.
showcrop
PostPosted: Mon Dec 18, 2017 4:32 am    Post subject: Re: 6.0 Coolant leak Reply to specific post Reply with quote
CVPost-ASEguy wrote:
(quoted from post at 04:24:24 12/18/17) Some coolants have dye in them. If your doesn't, put some dye in it and pressure test it or run it sitting still then shut it off and start looking. We use yellow glasses and a blacklight to aid in locating the dye.
I may have tottery that. The tough thing is that it doesn't leak until maybe 18 hours after shutting off.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
