John Deere 48 Loader - Front Mounting Bracket
Glen D Anderson
PostPosted: Fri Dec 01, 2017 4:43 pm    Post subject: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
Hello,
I'm the market for the seemingly elusive front mounting bracket for a John Deere 48 loader.
Item # 27, P/N C19239 as per the diag. & details below.
If anybody has one they'd be willing to part with or perhaps even share some detailed pictures of one with some measurements so I could fab. my own I'd be very grateful.
TIA,
Glen
tomstractorsandtoys
PostPosted: Fri Dec 01, 2017 6:31 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
I am missing one as well. I have one at a welding shop right now getting two made. He farms as well so it got put on hold but it should be done in a few weeks as his corn is now done. I will try to post back pics and let you know how it turned out. Tom
Hogleg
PostPosted: Sat Dec 02, 2017 5:42 am    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
Had one on my last tractor. Should be able to make one if you mount the loader on the tractor and support the front. A proper size piece of C channel with a backing plate should be enough. On mine, only the bottom set of holes were bolted to the tractor. It was on a 2550.
John
Glen D Anderson
PostPosted: Sat Dec 02, 2017 2:04 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
Thanks Tom, that'd be great!
CVPost-tomstractorsandtoy wrote:
(quoted from post at 19:31:48 12/01/17) I am missing one as well. I have one at a welding shop right now getting two made. He farms as well so it got put on hold but it should be done in a few weeks as his corn is now done. I will try to post back pics and let you know how it turned out. Tom
Glen D Anderson
PostPosted: Sat Dec 02, 2017 2:15 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
The mount is not actually for a loader, it's for a snow plow that we purchased which was built to attach via 48 loader mounts.
I have a plan in mind how I'll build the mount but would like to have the dimensions as close as possible to factory on the offchance we ever get a 48 loader.
Hogleg wrote:
(quoted from post at 06:42:23 12/02/17) Had one on my last tractor. Should be able to make one if you mount the loader on the tractor and support the front. A proper size piece of C channel with a backing plate should be enough. On mine, only the bottom set of holes were bolted to the tractor. It was on a 2550.
John
Hogleg
PostPosted: Sun Dec 03, 2017 6:26 am    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
Some pics - hope they help.
Glen D Anderson
PostPosted: Mon Dec 04, 2017 8:16 am    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
Thanks for the pics.!
The main measurements I'm looking for are:
Width - The maximum width of the mount pocket.
Depth - The distance between the bottom of the mount pocket & the bracket to tractor mounting surface.
Mounting bolt holes - Are they centered with the mount pocket?
Hogleg
PostPosted: Mon Dec 04, 2017 8:54 am    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
The tractor was traded in but still is on the dealer's lot. I will try to get these measurements for you. Also, maybe some closeup pics.
On my tractor, there were 4 holes on the front end bolster. The bracket has 4 holes also, but was mounted such that the bottom bracket holes were bolted to the top bolster holes. The upper part of the bracket was above the bolster in front of the grill (you can see that in the first pic). The second pic shows that the support arms for the loader were parallel with the ground on the bottom line. Having them any lower would have caused the front end to hit the travel stops too much.
I was told that this loader on a 4020 would be similar in that they would only use 2 sets of holes to mount the loader bracket, but I have not visually confirmed that to be true.
John
Glen D Anderson
PostPosted: Mon Dec 04, 2017 2:35 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
Thanks John!
I didn't realize that the tractor was not in your possession so I'm doubly grateful for you taking your time to get the measurements.
I managed to find a picture on the 'net of a 4020 with a 48 front bracket installed & I think it answers my question of whether the mounting holes are centered with the mount pocket.
So, it looks like I only need the width & depth measurements.
Hogleg wrote:
(quoted from post at 09:54:23 12/04/17) The tractor was traded in but still is on the dealer's lot. I will try to get these measurements for you. Also, maybe some closeup pics.
John
Kansas4010
PostPosted: Mon Dec 04, 2017 4:38 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
I have one on a 4010 I can take a picture
of. It's to dark tonight but I'll get one
tomorrow.
Kansas4010
PostPosted: Tue Dec 05, 2017 8:35 am    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
The 4010 isn't a good starter in the cold so
it's put to bed for the winter. I forgot I
put a squeeze chute in front of it close
enough I couldn't get a very good picture.
I can try again if these aren't good enough.
Glen D Anderson
PostPosted: Tue Dec 05, 2017 7:42 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
That is perfect, thank you very much!
CVPost-Kansas4010 wrote:
(quoted from post at 09:35:33 12/05/17) The 4010 isn't a good starter in the cold so
Glen D Anderson
PostPosted: Tue Dec 05, 2017 7:48 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
Just a quick thank you to everyone who offered their assistance with this.
It is much appreciated!
Glen
Kansas4010
PostPosted: Tue Dec 05, 2017 8:09 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
If you do end up making one could you post a picture of it. I've been looking for a second set of mounts to put my loader on another tractor.
Glen D Anderson
PostPosted: Tue Dec 05, 2017 11:01 pm    Post subject: Re: John Deere 48 Loader - Front Mounting Bracket Reply to specific post Reply with quote
You bet!
It might be a while before I get to it as the tractor I plan on installing it on is in pieces in the shop. Gotta get it back together along with some other projects out of the way before I can work on the snow plow.
If all goes well I'll have it done by spring when the snow is gone. LOL
(quoted from post at 21:09:11 12/05/17) If you do end up making one could you post a picture of it. I've been looking for a second set of mounts to put my loader on another tractor.
