got my eye on one
ericlb
PostPosted: Sat Dec 02, 2017 11:38 am    Post subject: got my eye on one Reply to specific post Reply with quote
i would like some opinions, a friend and i found a ford 901 diesel select o shift [ i know, but if it works...] it looks like a high crop with drop down final drives, taller tires and drop down wide front, im not all that familiar with the bigger fords,price seems reasonable, its in work clothes and seems to be honest from the pics, to see it in person which ill do is a 200 mile drive one way my thinking it there isnt many of these out west here and it might be worth picking up
R Geiger
PostPosted: Sat Dec 02, 2017 1:52 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
Piece of junk, Get an N.
Ultradog MN
PostPosted: Sat Dec 02, 2017 3:14 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
I would not bother.
Those diesels are sweet, the row crops (not high crop) are fun and powerful but the Select O Speeds are not for the average man.
If you have the skills to overhaul a C6 automatic transmission out of a 1970s Ford automobile maybe. You gotta get The Manual just to change the oil filter in them or adjust the gear selector lever, remove the top cover, adjust the bands or check the servo pressures. You up for that level of a learning curve? If so go for it.
Some guys love the things.
I have one of those transmissions. I like the tractor it's in but not that transmission. Mine is a later model. Supposedly they had the kinks worked out of them by then. To me it is an agravating, jerking darned thing to drive.
One of Fords biggest boondoggles ever was that transmission.
Look into the Ford 6000. In some ways it was way ahead of its time. They ONLY came with that SOS transmission. And I'll bet there aren't 20% of them still in service -on account of those Jerk O Matics.
wellmax99
PostPosted: Sat Dec 02, 2017 4:04 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
Years ago I helped an old man hook up a cultivator to a ford tractor with this transmission,
I was going to get in close so I could attach the lower arms,
He said stand back as I can only move this thing 6? at a time, it was wild, but we finally drug it around and got it hooked up,
I did not like it very much, but the transmission may have been in need of repair,
showcrop
PostPosted: Sat Dec 02, 2017 4:11 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
I have one and I like it and I use it a lot. It is highly unlikely that it is an original Select-O-Speed, nearly all of them were changed out at the factory for the second generation SOS, but a few got by. Many of the later models with the SOS are still working regularly. It is true that parts are hard to get but that is the case with many of the 60 year old tractors. They also have their quirks like creeping when in neutral until warmed up. People say that they jerk when shifting. I suppose they do. As UD said it is highly unlikely that it is a high crop, much more likely that it is a row crop.
L.Fure
PostPosted: Sat Dec 02, 2017 5:22 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
I have a friend that has a 900 series with Select-o-matic transmission. His shifts really smooth.
showcrop
PostPosted: Sat Dec 02, 2017 6:30 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
showcrop wrote:
(quoted from post at 17:11:50 12/02/17)
I meant changed out at dealers under a factory program.
tractorguy2
PostPosted: Sat Dec 02, 2017 7:02 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
It not a high crop. it's a row crop. They were made for more ground clearance for cultivating. My dad has a 1962 4000 row crop SOS gas. Dads 4000 is just a newer version of a 971.
The transmission works very well. When moving snow the 4000 will run circles around the 706. My two biggest complaints. One, it is hard to get on and off. Two, With the wide front it will not turn short.
On dads SOS you adjust the bands from the outside. No need to remove the cover.
Colin King
PostPosted: Sun Dec 03, 2017 6:46 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
I have the 961 (5spd) diesel and absolutely love it. Lots of power, and incredibly easy on fuel. For light work, it uses about 75% of the fuel the N does. Regarding the Select-O-Speed, if the price is good (a 901 or 801 diesel in my neck of the woods will easily run $4k in work clothes), swap the tranny with the 5spd from a boneyard or parts tractor.
Colin, MN
W_B
PostPosted: Mon Dec 04, 2017 11:28 am    Post subject: Re: got my eye on one Reply to specific post Reply with quote
CVPost-Ultradog MN wrote:
(quoted from post at 00:14:52 12/03/17) Look into the Ford 6000. In some ways it was way ahead of its time. They ONLY came with that SOS transmission. And I'll bet there aren't 20% of them still in service -on account of those Jerk O Matics.
Our 6000 Commander was a nice running tractor and the transmission wasn't a big problem, except it had a seal that kept leaking between the transmission and the rear end. The dealer had it twice fixing it in the relatively short time we had it. Otherwise we really liked it. It was a bit herky-jerky however. When we owned the thing it wasn't that old, I think Dad bought it in 1971-72.
Billy NY
PostPosted: Mon Dec 04, 2017 4:30 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
Can't disagree more, owned one for many years and did everything on the farm with it. There's got to be more to the "jerkyness" in regards to repair or adjustment. Mine was good in that respect, sure you knew it was shifting but nothing drastic, it was smoother than not from starting off to upshifting and downshifting. It was formerly a highway mowing tractor, racked up plenty of trouble free hours over the years too.
grandpa Love
PostPosted: Mon Dec 04, 2017 8:22 pm    Post subject: Re: got my eye on one Reply to specific post Reply with quote
If the price is right go for it. Everyone has an opinion. Go form your own! Lol. If sos is crap swap it out for a 5 speed. Post some pictures.
