Teflon tape hydraulic pump plug ??
DanGrandville
PostPosted: Sun Dec 03, 2017 6:37 am    Post subject: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
I recently obtained a ford 861 tractor. Wondering if there is any issue with placing Teflon tape on the threads of the bleed plug at the top of the hydraulic pump?
Also the hydraulic fluid dip stick has two sides with wildly different marks for full. Any help on which side to read and under what conditions would be helpful.
Thanks,
Dan
Michaels Dad
PostPosted: Sun Dec 03, 2017 6:45 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
DanGrandville wrote:
(quoted from post at 10:37:35 12/03/17) I recently obtained a ford 861 tractor. Wondering if there is any issue with placing Teflon tape on the threads of the bleed plug at the top of the hydraulic pump?
Thanks,
Dan
Most say don't use tape on hydraulics.
Reason is a lot of people don't know how to use the tape. When wrapping a fitting they have let the tape go over the end of a fitting. What happens then is that piece of tape gets cut off when the fitting is tightened and then this piece enters the system causing problems.
There are better choices for thread sealers.
Mike(NEOhio)
PostPosted: Sun Dec 03, 2017 6:48 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
It's OK to use tape as long as it's wrapped in the right direction and the edge stays two threads back from the end of the plug.
DanGrandville
PostPosted: Sun Dec 03, 2017 6:51 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
Thanks, I won't use teflon.
David G
PostPosted: Sun Dec 03, 2017 6:57 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
I use PTFE compound
Bern
PostPosted: Sun Dec 03, 2017 8:24 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
Teflon tape is just fine if used correctly. You need to put something on tapered threads so it won't leak.
Lynn Patrick
PostPosted: Sun Dec 03, 2017 8:47 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
Can't say for sure for an 800, but that dipstick (maybe the same one?) on a 900 says something about the front pedestal on one side & is used to measure the lubricant level there. The other side is for the hydraulics.
John Deere D
PostPosted: Sun Dec 03, 2017 9:21 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
I use PTFE compound :
Here is one supplier....
Texasmark1
PostPosted: Mon Dec 04, 2017 5:09 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
Agree with all the answers. Thanks for the tip on Locktite 577.
Fred Werring
PostPosted: Wed Dec 06, 2017 6:22 am    Post subject: Re: Teflon tape hydraulic pump plug ?? Reply to specific post Reply with quote
What Mike said. I've used it for years, long as you do it the way he described you'll be fine.
Fred
