jcb 1400b backhoe
ricky jcb
PostPosted: Sun Dec 03, 2017 1:52 pm    Post subject: jcb 1400b backhoe Reply to specific post Reply with quote
Hey,I recently purchased a 1988 jcb 1400b backhoe.I can operate machine about 2 to 3 hours and it will come to a slow idle then engine will shut off.I have changed all the filters including fuel and installed a manual temp. gauge.I thought overheating might be problem.Temp. max.only about 180.Could it be an electrical issue?
John730D
PostPosted: Sun Dec 03, 2017 4:04 pm    Post subject: Re: jcb 1400b backhoe Reply to specific post Reply with quote
Is the fuel tank vent plugged? Loosen fuel cap and try it again. Yes I have had it happen on a diesel even with a lift pump.
AJ.
PostPosted: Mon Dec 04, 2017 1:07 am    Post subject: Re: jcb 1400b backhoe Reply to specific post Reply with quote
Perkins 4.236,there is a washable gauze in the feed pump,undo the screw in the center of the dome and remove the gauze,clean it and the body of the pump and see how you fare.
AJ
ricky jcb
PostPosted: Mon Dec 04, 2017 4:25 pm    Post subject: Re: jcb 1400b backhoe Reply to specific post Reply with quote
Will try that.Thanks
ricky jcb
PostPosted: Mon Dec 04, 2017 4:27 pm    Post subject: Re: jcb 1400b backhoe Reply to specific post Reply with quote
Ok will try that.Thanks
1130Leo
PostPosted: Wed Jan 03, 2018 1:44 pm    Post subject: Re: jcb 1400b backhoe Reply to specific post Reply with quote
Possible the fuel filter under the cab on the drivers side is sucking air?
