2000 Dodge 318
Goto page 1, 2, 3  Next
Dave8N in Pa
PostPosted: Sun Dec 03, 2017 2:25 pm    Post subject: 2000 Dodge 318 Reply to specific post Reply with quote
My old van has been a work-horse but it's getting tired. I just changed the TPS but it didn't help. It runs good cold but when it get warmed up it starts to pop thru the carb. If I'm on level ground and barely touch the throttle it's OK. The least little pull and it starts popping thru the carb. It has a check engine light ON but I don't have a code reader. I know I can take to a garage but I thought I could rule out some of the simple stuff first. Anybody got an idea?
Roger in Iowa
PostPosted: Sun Dec 03, 2017 3:00 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
Turn the key three times to the run position (NOT START) and stop on the third time. The speedo digital readout will give you codes, be ready to write or tell some so they can write them down. You can find the meaning of the codes on the net.
Steve@Advance
PostPosted: Sun Dec 03, 2017 3:49 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
Have you checked the fuel pressure?
davpal
PostPosted: Sun Dec 03, 2017 3:57 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
Sounds like the timing chain might be worn out.
oldsarge
PostPosted: Sun Dec 03, 2017 4:08 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
75K is good time to change timing chain on 318,mine would jump in and out of time.easy fix in van,just lift out radiator and sit down in front of job. 'course mine was a '77
jacksun65
PostPosted: Sun Dec 03, 2017 4:22 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
Year 2000 dodge was 5.2 Multiport fuel injection. sounds like pcm may need to be re flashed. timing is set by computer non adj.
MtMan
PostPosted: Sun Dec 03, 2017 5:40 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
Dave, I can't help you with your auto problem, but I sent you a message a couple of days ago . Just wanted you to know That I really enjoyed our phone conversation the other day. It's nice to get a personal contact with folks from here on the net. How did the Mrs. make out with her surgery. Good I hope and feel free to call anytime you wish. Again Thanks.
David G
PostPosted: Sun Dec 03, 2017 5:48 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
It is impossible to know, as suggested pull the codes first.
Clarence Slydell
PostPosted: Sun Dec 03, 2017 6:24 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
The carbs on those 2000 Dodges needed rebuilt right from the factory.
Roger in Iowa
PostPosted: Sun Dec 03, 2017 6:57 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
Believe 1986 was the last year for carbs. At least on the Power Ram pickups.
Roger in Iowa
PostPosted: Sun Dec 03, 2017 7:06 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
I can see jumping out of time. How can it jump into time?? Jumping out, shouldn't it not run?
Aaron Ford
PostPosted: Sun Dec 03, 2017 7:11 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
Would a temperature sensor cause this? Sounds like the codes need to come off it, for sure.
Aaron
David G
PostPosted: Sun Dec 03, 2017 7:18 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
Should not be any carb on 2000
marloweg
PostPosted: Sun Dec 03, 2017 9:01 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
oxygen sensors two of them
marloweg
PostPosted: Sun Dec 03, 2017 9:02 pm    Post subject: Re: 2000 Dodge 318 Reply to specific post Reply with quote
no carb throttle body
Page 1 of 3
