Steering locks up on my 730
chas036
PostPosted: Sun Dec 03, 2017 2:30 pm    Post subject: Steering locks up on my 730 Reply to specific post Reply with quote
Sometime when I turn my steering wheel all the way to the left or right, it locks up and I have to use a lot of force to free it. Is this a problem in the pedestal or vanes area, or in the worm housing and steering valve?
Bob
PostPosted: Sun Dec 03, 2017 3:59 pm    Post subject: Re: Steering locks up on my 730 Reply to specific post Reply with quote
They'll do all sorts of weird things when the "ramp" on the steering worm that operates the steering valve wears or chips badly.
If the "cylinder" the vanes run in isn't centered around the vanes, or is damaged, or the bolts that hold the moveable vane to the steering shaft come loose or break, it will jam, as well.
Probably some other possibilities, as well.
ET
PostPosted: Mon Dec 04, 2017 4:26 am    Post subject: Re: Steering locks up on my 730 Reply to specific post Reply with quote
Things are loose in the steering valve and worm and sector. The worm gear end play is excessive, the backlash between the worm and sector needs adjusting, and the two dowel pins inside the sleeve have flat spots on them.
jddrawbar
PostPosted: Mon Dec 04, 2017 7:54 pm    Post subject: Re: Steering locks up on my 730 Reply to specific post Reply with quote
Had the same issue on my 730 yrs. ago and it was the bearing in the bottom of the pedestal.
ET
PostPosted: Tue Dec 05, 2017 4:22 am    Post subject: Re: Steering locks up on my 730 Reply to specific post Reply with quote
When you look at that lower bearing remember it is a thrust bearing and it does not have a cage on the balls in it, they are free floating.
rick deere
PostPosted: Tue Dec 05, 2017 3:18 pm    Post subject: Re: Steering locks up on my 730 Reply to specific post Reply with quote
Had one of those once , has chip broken off worm gear.
