Spark Plug blow by - Is my 2N head dead?
Goto page 1, 2  Next
allenlane
PostPosted: Sun Dec 03, 2017 5:34 pm    Post subject: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
Just got my 2N running after sitting up for 3-4 years. I'm not getting any smoke at all out of the exhaust pipe, but I can see a little oil build up around the base of the #4 plug. I took it out and can see the plug seat has rusted slightly so the seat is not sealing under the plug. I've not done a compression test yet, but that #4 plug is pretty black, so I likely will need a ring job in the future.
Question - Is my head shot? Any way to fix it?
shaun wallace
PostPosted: Sun Dec 03, 2017 5:59 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
Are the plugs 437 autolite and do all have gaskets/seal ring on them. With no gaskets and loose will leak around them.
tractorguy2
PostPosted: Sun Dec 03, 2017 6:14 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
Black plugs are pretty much normal. I would start with new
plugs.
allenlane
PostPosted: Sun Dec 03, 2017 6:21 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
They are HO12's and #4 is the only one leaking. I tightened it down much more than the others and reduced the leaking substantially. That head design, with the recessed plug cavity must be conducive to having moisture and junk settle in there for tractors that live outside, as many of them do.
allenlane
PostPosted: Sun Dec 03, 2017 6:23 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
The plugs are brand new.
Bruce (VA)
PostPosted: Sun Dec 03, 2017 6:44 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
Get a thread chaser and clean the threads. Make sure the plug is seated correctly and has a gasket.
If the threads are wallowed out, you can fix it, or just replace the head.
75 Tips
Tim PloughNman Daley
PostPosted: Mon Dec 04, 2017 8:28 am    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
The 14mm plug, original FORD spec'd for Champion H10, now can use a hotter plug, Champion H12 (numbered 512 now)or the equally good Auto Lite 437 plug. Gap spec is .025" -.027". The lug thread size is METRIC -14mm x 1.25mm (thread pitch, TPI, Threads Per Inch)) -DO NOT USE ANYTHING ELSE!!!
Tim Daley(MI)
allenlane
PostPosted: Mon Dec 04, 2017 6:26 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
What am I missing? I'm talking about the honed section of the head that the plug washer seals/seats against being rusted out /worn...and you guys are talking about threads. The threads are fine and yes, of course there is a washer. Doesn't sound like a worn head is a common problem.
R Geiger
PostPosted: Mon Dec 04, 2017 7:00 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
allenlane wrote:
(quoted from post at 20:26:30 12/04/17) What am I missing? I'm talking about the honed section of the head that the plug washer seals/seats against being rusted out /worn...and you guys are talking about threads. The threads are fine and yes, of course there is a washer. Doesn't sound like a worn head is a common problem.
If the threads are damaged it is possible the plug is not seating all the way, which would cause it to leak. the washer should crush causing it to seal even on a corroded surface. IMHO
kylemorley
PostPosted: Mon Dec 04, 2017 7:38 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
If it isn't too far gone, It might be worth trying a real, solid, copper plug washer, and anneallng it by heating it up red hot and dropping it into water. to soften it so it will make a better seal. This is
standard practice in the light aviation world and perfectly safe. Don't be shy about annealing it several times in a row. If it works you probably will have to replace the washer/gasket anyrtime you
remove the plug, no problem, the copper gaskets can be annealed many times.
Otherwise your best bet is to take the head to a decent automotive machine shop and see what they can tell you.
You'd think it would be a common enough problem that any decent auto machine shop would have a spark plug seat refacer but I can't recall ever seeing one. You could mill or turn it, but that could
easily end up costing as much as a new head.
Jim WI
PostPosted: Tue Dec 05, 2017 12:23 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
Spark Plug Hole Conditioning Tool
Bruce (VA)
PostPosted: Tue Dec 05, 2017 12:34 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
" Spark Plug Hole Conditioning Tool "
Interesting. I've always called them spark plug thread chasers. Hence my comment " Get a thread chaser and clean the threads."
Learn something ne everyday around here!
75 Tips
TheOldHokie
PostPosted: Tue Dec 05, 2017 3:57 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
CVPost-Bruce (VA) wrote:
(quoted from post at 16:34:18 12/05/17) " Spark Plug Hole Conditioning Tool "
Learn something new everyday around here!
That is more than a thread chaser - it has a (crude) spring loaded seat cutter in addition to the thread chasing section.
This is an ordinary thread chaser.
TOH
allenlane
PostPosted: Tue Dec 05, 2017 5:54 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
I think Jim and Hokie have hit the nail on the head. All I need is about 1/16 to get a flush seat. Is anybody worried that I don't have enough clearance with the TDC of the piston?
TheOldHokie
PostPosted: Tue Dec 05, 2017 6:04 pm    Post subject: Re: Spark Plug blow by - Is my 2N head dead? Reply to specific post Reply with quote
allenlane wrote:
(quoted from post at 21:54:18 12/05/17)
I'm not worried. I'd say there ain't a snow ball's chance in he!! that the seat cuttor on that BG tool will remove 1/16" of cast iron Rolling Eyes
TOH
Goto page 1, 2  Next
Page 1 of 2
