8N Sitting 20+years
Goto page 1, 2  Next
MountainGoat
PostPosted: Mon Dec 04, 2017 7:12 am    Post subject: 8N Sitting 20+years Reply to specific post Reply with quote
My neighbor has an 8N (1950 from the SN) that has been sitting uncovered in the woods for 20+ years. It has a front end loader so I worked a deal with him that I can use it if I get it operational. Tires are flat and the rubber is starting to peel apart. I figure I'd start with figuring out if it is locked up or not and follow that with a compression test. It is still 6V, but I thought I would use a 12V for the test and just disconnect the regulator and generator so I would have no investment until this test is done. Going to squirt some ATF in the holes first. It does have oil in the crank case. Black, but no water in it. Hopefully I can get past these first few tests and continue to bring it back from the dead. I don't need a total project, so one step at a time. And if I hit a hard stop, then that's how it goes. Early 50, so none of the improvements for that year. Very stock and un-messed with. It does sport a Hupp Dual Drive tranny so that was a nice surprise. Any advice for waking it from the 20yr slumber? I'm new to 8N's so any way to prime the oil pump? On Windsor motors, you can use a drill running CCW to drive the oil pump with the distributor out. Hate to start completely dry on the shell bearings.
Paul in MN
PostPosted: Mon Dec 04, 2017 8:05 am    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
There is a lot of discussion in the archives about priming the oil pump, and I fully agree that is a huge benefit to the engine bearings. After priming, spin the engine with the starter (with IGNITION OFF) to get oil flow to all bearings. Don't worry about the oil filter possibly being plugged, it is a bypass filter so no oil needs to go through it to get to the critical engine parts.
When an 8N has sat for considerable time, the clutch is frequently rusted tight to the flywheel. Be absolutely SURE that the tranny shift is in NEUTRAL before you try to jump start with 12 V. Usually this does not hurt the starter motor. But do not let it crank for long periods of time as it can overheat.
Don't expect it to start, as the ignition points are usually corroded by moisture over the long period of setting. I do not use ether to test start, but get better results from using spray carb cleaner directly into the throat of the carb.
A lot of these old N's can be brought back to life, so good luck with your adventure.
Paul in MN
HCooke
PostPosted: Mon Dec 04, 2017 8:21 am    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
"any way to prime the oil pump? "
Looking at the timing cover there is one bolt that is larger than the other at about 1 o'clock. 15/16s if memory is good. Remove it and the
pressure relief valve and spring under it. Pump (squirt) a cup of heavy oil in there and replace the valve spring and bolt.
Den N Ms
PostPosted: Mon Dec 04, 2017 9:08 am    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
MountainGoat The first thing I would check for is a cracked block on the left side below the head, around the welsh plugs and block drain.Some one let it set for some reason.With a loader easy repair would be tough.Bad tires and cost to replace them you might want a sleeping dog to stay asleep and keep piece with your neighbor.If it is not cracked go for it and get it running,many have been brought back from the dead.The easiest place to prime the oil pump is at the oil pressure gauge line with a oil pump can or pump up sprayer with heavy weight oil and a piece of vacuum hose.
MountainGoat
PostPosted: Mon Dec 04, 2017 9:28 am    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
Thanks Paul. Not expecting it to start. Only trying to ascertain basic engine condition at this point. I need to have a discussion about the tires as well before proceeding, as that cost is probably a show stopper. If it's froze up, then it's absolutely game over. There's plenty around me for sale. Just not any with a front loader, and that's what I need.
MountainGoat
Awesome! Thanks!
MountainGoat
PostPosted: Mon Dec 04, 2017 9:40 am    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
Thanks Den. It was his dad's and when the farm sold, he brought it to his house. Drove it to where it is parked. Radiator cap is off. Don't know how long that's been that way. I tried to buy it a few years ago, but too much sentimental value. That's how I came to the fix it/use it deal. Sheet metal is very straight. Will definitely look for cracks - after I get some of the other things piled up against it away. Was a bit of effort to just get the SN, lol. Hadn't thought about the clutch. Or the brakes for that matter. One step at a time. If she's not stuck and has decent compression, and we come to an agreement about the wheels, I will do a tune up and a carb rebuild. I might just be buying this tractor one piece at a time...
Kirk-NJ
PostPosted: Mon Dec 04, 2017 10:30 am    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
Been sitting outside for 20 yrs. Something will be stuck, engine valves,clutch Or all of the above. take your time and go slow. Don't invest in something that will cost you more than it's worth. Tires are a
big ticket item.
Kirk
DoubleO7
PostPosted: Mon Dec 04, 2017 2:21 pm    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
Also, depending on location it might be important to know how strong the antifreeze is.
With the rad cap off rad might be dry if rain diluted the mix and then every time it froze it split the tubes all the way down.
steve19438
PostPosted: Mon Dec 04, 2017 3:14 pm    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
funny thing is if you do get it running the neighbor may have a change of heart. walk away.
cowdog
PostPosted: Mon Dec 04, 2017 4:28 pm    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
It's a waste of time. The money you spend on it would be better served to get a tractor that already runs and belongs to you. You can buy a nice 601 workmaster for less than the cost of an 8N in my area and twice the tractor to boot.
hd6gtom
PostPosted: Mon Dec 04, 2017 5:14 pm    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
Totally agree with cowdog. I have hauled many of them to the scrapyard after they have set that long, none
were worth spending a dime on.
Ultradog MN
PostPosted: Mon Dec 04, 2017 5:32 pm    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
I would be willing to gamble about $25 on
this thing. And that is if the engine
turns over. Part of that would be for a
can of MMO which I would dump down the sp
holes regardless. The rest would be for
gas and rigging up a temporary gas tank.
That tractor sounds like a big money pit
to me. Tires sound shot, you just know the
rods on all the loader cylinders are rusty
after sitting out that long, who knows if
the clutch or the gears or the hydraulics
aren't bad plus whatever it was that made
the tractor get discarded in the first
place.
These little Fords are fun and handy. But
there's oodles of the things out there
that already run and can be bought
cheaply. So it is foolish to try to
resurrect a cast-off like this especially
if you dont even own the thing.
Dollar Bill
PostPosted: Tue Dec 05, 2017 2:06 am    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
As previously mentioned; Run! Run far away from this deal.
- Anything that has sat, unused for 20 years is going to require a LOT to bring it back to life.
- N's are not good loader platforms due to weak front end and lack of power steering. Depending on the type of loader, they can be hard to get on and off of.
- Investing in someone else s tractor is a mine field of things that can go wrong. Not sure what kind of man your neighbor is but his agreeing to the deal makes me question his motives.
- Verbal agreements are binding but difficult to prove and it sounds like you're the only one contributing.
MountainGoat
PostPosted: Tue Dec 05, 2017 4:45 am    Post subject: Re: 8N Sitting 20+years Reply to specific post Reply with quote
Believe me, I'm not going to restore this ride. I have enough to do. Yeah, the cylinders are rusty on the loader. The more I look at it, the more it looks like a restoration. If I had the space, time and if I had a stash of parts, and that's what I was trying to accomplish I would not hesitate, but I have none of that. I spent last night looking at other tractors on craigslist. Found a couple of candidates in the 2-3k range that will need some love, but are not the total unknown this one is currently. I had originally budgeted about 100 bucks to get this going, but that's before I actually looked it over. I will at least assess it's condition and tell him what's going on. Dragging a battery and a compression gauge down there and burning up a half hour doesn't cost anything. It is a good candidate for restoration as the sheet metal is straight and it's complete. I'm not looking for that. I'm looking for a workhorse. My original plan was to rebuild the carb, change the fluids, clean out the tank and maybe replace a hose. This is a long way from getting there. The tires are another show stopper. Thanks for the advice guys. Search continues.
Goto page 1, 2  Next
Page 1 of 2
