175 3 point lift response
21hunter
PostPosted: Mon Dec 04, 2017 7:15 am    Post subject: 175 3 point lift response Reply to specific post Reply with quote
Hello, the 3 point lift on my 175 is slow to respond with the position lever. It is most noticeable when lowering the lift with an approximate 2-3
second delay from the down movement of the position lever until the arms start moving down. I was using a grader box this weekend and the
slow response makes it more difficult to do a good job. Does anyone know if there is a way to speed up the response? Could the dashpot
cause a delay? Is the dashpot necessary if I don't use the tractor for a mounted plow or other implement where I use the draft Control? I've
tried different draft and response lever settings to no avail. A new lift pump was installed and the hydraulic system was adjusted according to
the repair manual........so I thought.
Dieseltech
PostPosted: Mon Dec 04, 2017 8:00 am    Post subject: Re: 175 3 point lift response Reply to specific post Reply with quote
Do you have the response adjustment on the dipstick side cover set to Fast, all the way forward?
21hunter
PostPosted: Mon Dec 04, 2017 9:53 am    Post subject: Re: 175 3 point lift response Reply to specific post Reply with quote
Yes, I do. Can't tell any difference between fast and slow.
