Wide front casting SC
Goto page Previous  1, 2, 3
L.Fure
PostPosted: Wed Dec 06, 2017 2:42 pm    Post subject: Re: Well, here it is Reply to specific post Reply with quote
fixerupper wrote:
(quoted from post at 21:53:00 12/06/17) Here's the brazing job. Craters of the moon.
Looks like you need a little less heat and more brass. It also looks like you didn't keep the flame moving in a circular motion. You can grind out the bad spots and try it again. Other then a few thing I mentioned you did a pretty good job. Just don't be afraid of using lots of brass rod while brazing.
fixerupper
PostPosted: Wed Dec 06, 2017 4:03 pm    Post subject: Re: Well, here it is Reply to specific post Reply with quote
Thanks so much for the advise. This is my first rodeo with heavy casting. I was not circling much. Now that you mention it, circling is important. The memory needed to be jogged a bit. LOL Here is the final finish.
I ground it down feathered the edges and hit it with the needle scaler. With a coat of paint it might fool a few people if they don't look too close.
L.Fure
PostPosted: Wed Dec 06, 2017 4:26 pm    Post subject: Re: Well, here it is Reply to specific post Reply with quote
It looks a lot better after you cleaned it up. Be sure to post a picture of it after you paint it and put it back together. Was the owner alright with the repair you did, or does he still want a replacement? I think your repair will hold up alright. If the part cracks it will be in a different spot.
fixerupper
PostPosted: Wed Dec 06, 2017 4:39 pm    Post subject: Re: Well, here it is Reply to specific post Reply with quote
The picture doesn’t show it but I did leave it slightly raised. I haven’t talked to the owner. I’ll show him the casting after a paint job and let him decide what to do. Finding a good unbroken casting that someone wants to let go of will be very hard to do. I have a hunch an unbroken casting will have small cracks starting unless it’s a NOS part. The casting is only 1/2” thick in the area that tends to crack.
fixerupper
PostPosted: Thu Dec 07, 2017 1:35 pm    Post subject: Re: Well, here it is Reply to specific post Reply with quote
One coat of epoxy primer and one coat of
power red. Couldn't readily find flambeu in
a good quality paint. Will have to wait for
it to dry to see if there is a difference.
L.Fure
PostPosted: Thu Dec 07, 2017 4:28 pm    Post subject: Re: Well, here it is Reply to specific post Reply with quote
CVPost-Fixerupper wrote:
(quoted from post at 22:35:33 12/07/17) One coat of epoxy primer and one coat of
A coat of paint will cover a multitude of sins.
The only way to tell there was a repair made on the bolster, is that the repaired portion is smoother than the rest of the casting. Now you can add this to your résumé of skills.
fixerupper
PostPosted: Thu Dec 07, 2017 7:23 pm    Post subject: Re: Well, here it is Reply to specific post Reply with quote
It's put together now. The heating shrank it a bit. I had to use a sanding wheel to ream it to get the bolster to come down on the front end without pounding on it. I figured putting it together extra tight is inviting another crack to start. Thanks so much for the encouragement and advice. Next time I will use less heat, more rod and do the swirling. There's nothing as good experience.
Page 3 of 3
