3020 starter solenoid
Goto page Previous  1, 2
JDEM
PostPosted: Mon Dec 04, 2017 6:41 pm    Post subject: Re: 3020 starter solenoid Reply to specific post Reply with quote
Could be but post a photo here so we know exactly what you are seeing. Does it look like the relay I posted?
SVcummins
PostPosted: Mon Dec 04, 2017 8:13 pm    Post subject: Re: 3020 starter solenoid Reply to specific post Reply with quote
I?ve used a 1/4 inch 9/16 socket with a swivel and long extension to get the hind bolt out
Randy G
PostPosted: Mon Dec 04, 2017 9:06 pm    Post subject: Re: 3020 starter solenoid Reply to specific post Reply with quote
I also had the same problem w/my 2940. Turn the key, some times start, sometimes clicking only. Installed the kit TX Jim mentioned and the problem was fixed. Not enough voltage was getting to the starter but the kit gives 12v directly to the starter w/o affecting the safety switch.
Tx Jim
PostPosted: Tue Dec 05, 2017 3:02 am    Post subject: Re: 3020 starter solenoid Reply to specific post Reply with quote
CVPost-sandel wrote:
(quoted from post at 18:12:54 12/04/17) Is the starter relay you reference the one in the picture? If so is it the device located in a little box like enclosure directly above the back end of the starter?
If relay was factory installed will depend on tractor serial number but yes 3020's after SN 123,000 had starter relay on firewall above starter.
sandel
PostPosted: Tue Dec 05, 2017 3:50 am    Post subject: Re: 3020 starter solenoid Reply to specific post Reply with quote
Thanks to all of you. Appreciate the input.
Page 2 of 2
