1946 John Deere A governor disassembly
1956eagle
PostPosted: Mon Dec 04, 2017 6:31 pm    Post subject: 1946 John Deere A governor disassembly Reply to specific post Reply with quote
Can anyone tell me how to disassemble the governor from the governor case? Does the snap ring on the mag side have to come out first? Or should the whole assembly slide out once the gear cover has been removed?
John H.
greenmech
PostPosted: Mon Dec 04, 2017 6:47 pm    Post subject: Re: 1946 John Deere A governor disassembly Reply to specific post Reply with quote
It will come out the left side, but you need to loosen the fork on the speed control lever. Ron Mn
1956eagle
PostPosted: Mon Dec 04, 2017 7:03 pm    Post subject: Re: 1946 John Deere A governor disassembly Reply to specific post Reply with quote
Thanks for the reply so quickly. I have unscrewed the fork from the shaft. The whole governor assembly seems to be solidly still in the case. I just wanted to make sure I had not overlooked anything before trying to tap the shaft out.
Gene Davis (Ga.)
PostPosted: Mon Dec 04, 2017 7:32 pm    Post subject: Re: 1946 John Deere A governor disassembly Reply to specific post Reply with quote
Be sure to remove the magneto or the distributor before you try to reassemble it. The spring will break it if you
aren't careful.
RLA
PostPosted: Tue Dec 05, 2017 5:26 am    Post subject: Re: 1946 John Deere A governor disassembly Reply to specific post Reply with quote
You would swear it won't come out of the left side of the housing, but It will, once it's turned right & you loosen the
the flapper arm.
John T
PostPosted: Tue Dec 05, 2017 5:30 am    Post subject: Re: 1946 John Deere A governor disassembly Reply to specific post Reply with quote
1956eagle wrote:
(quoted from post at 19:31:54 12/04/17) Can anyone tell me how to disassemble the governor from the governor case? Does the snap ring on the mag side have to come out first? Or should the whole assembly slide out once the gear cover has been removed?
John H.
As I recall you also have to remove that oil line underneath that feeds the governor
John T
MSD
PostPosted: Tue Dec 05, 2017 7:29 am    Post subject: Re: 1946 John Deere A governor disassembly Reply to specific post Reply with quote
Try rocking the flywheel back and forth a little. It'll pop out then.
