M670 Tel-O-Flo Issues
dpatewi
PostPosted: Tue Dec 05, 2017 10:04 am    Post subject: M670 Tel-O-Flo Issues Reply to specific post Reply with quote
Need Help. I recently took off a loader from my 670 Super LP. It had a two lever loader valve mounted on the right fender. After removing that and hooking the lines back to the reservoir, and replacing the hydraulic filter and oil, I have no action now from the the system. Three point and rear hydraulics are inoperable. Did I lose prime in the system? Any help would be greatly appreciative.
Thank you,
molinegb
PostPosted: Tue Dec 05, 2017 10:29 am    Post subject: Re: M670 Tel-O-Flo Issues Reply to specific post Reply with quote
Had same problem. No 3 pt and no hydraulics at all. Pump wasn't turning. Shaft was twisted
off in pump. Previous owned must have had moisture in system and it froze. Water goes to
lowest point which is pump. Waiting for parts to rebuild. Drained system and there was
water in reservoir also. Hopefully not your issue.
dpatewi
PostPosted: Tue Dec 05, 2017 11:38 am    Post subject: Re: M670 Tel-O-Flo Issues Reply to specific post Reply with quote
CVPost-molinegb wrote:
(quoted from post at 11:29:18 12/05/17) Had same problem. No 3 pt and no hydraulics at all. Pump wasn't turning. Shaft was twisted
Thanks for the reply! I have to think its unlikely that its that, but will check it out. Everything worked when I drove it into the shop to remove the loader.
molinegb
PostPosted: Tue Dec 05, 2017 1:15 pm    Post subject: Re: M670 Tel-O-Flo Issues Reply to specific post Reply with quote
You should be able to hear pump or feel it to confirm rotation. If not could be coupler.
dpatewi
PostPosted: Tue Dec 05, 2017 7:16 pm    Post subject: Re: M670 Tel-O-Flo Issues Reply to specific post Reply with quote
Checked the gears, they turn. Then ran it with the pressure line off of the pump. Oil burped out. Hooked everything up again, ran it, now the hydraulics work. Thanks again for the starting tip!
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
