Hytran or Oil?
Johnnykick
PostPosted: Tue Dec 05, 2017 12:19 pm    Post subject: Hytran or Oil? Reply to specific post Reply with quote
Went to my tractor supply store to get some Hytran to put into my 1955 Farmall 100. The technician said he recommended straight 30W motor oil as it is a bit thicker and there would be a less likelihood of leaks.
steve706
PostPosted: Tue Dec 05, 2017 12:46 pm    Post subject: Re: Hytran or Oil? Reply to specific post Reply with quote
Only place 30w oil should be used on a 100 is the engine. HyTrans in hydraulics, gear oil in rear end.
Janicholson
PostPosted: Tue Dec 05, 2017 1:35 pm    Post subject: Re: Hytran or Oil? Reply to specific post Reply with quote
He we wrong. Hytran is substantially different in additives. Thirty wt. will be very stiff in the winter, and if it leaks fix the leak. Jim
D7fever
PostPosted: Wed Dec 06, 2017 4:50 am    Post subject: Re: Hytran or Oil? Reply to specific post Reply with quote
Use the hytran That is what it calls for, has different additives than 30 wt oil. I use the hytran in my '55 100.
BarnyardEngineering
PostPosted: Wed Dec 06, 2017 5:53 am    Post subject: Re: Hytran or Oil? Reply to specific post Reply with quote
Straight engine oil is what was originally used in the belly pumps of H's and M's. That is where he is getting his information from.
By the time the Super A's, C's and Cubs came out, IH had developed Touch Control Fluid which was a dedicated hydraulic fluid with the additives. Touch Control Fluid is the great-great-grandfather of Hytran Ultraction, the current product.
D beatty
PostPosted: Wed Dec 06, 2017 6:05 am    Post subject: Re: Hytran or Oil? Reply to specific post Reply with quote
If you read it again he got his information from a TSC employee who in most cases is hired right off the street and knows nothing about tractors and oils.
SuperHank
PostPosted: Wed Dec 06, 2017 8:32 am    Post subject: Re: Hytran or Oil? Reply to specific post Reply with quote
My SuperH manual calls for 30wt nondetergent. Detergent oil supposedly foams. I've used hytran and 30wt and both work. Live in Florida so temperature not an issue.
Johnnykick
PostPosted: Wed Dec 06, 2017 10:57 am    Post subject: Re: Hytran or Oil? Reply to specific post Reply with quote
Rural King sells Harvest King CASE IH Trans-Hydraulic Fluid. Would that be the same stuff?
DR. EVIL
PostPosted: Thu Dec 07, 2017 9:42 am    Post subject: Re: Hytran or Oil? Reply to specific post Reply with quote
Your Super H manual is SIXTY-THREE or SIXTY-FOUR years old. Hy-Tran didn't exist until 5-6 years after the SH manual was printed. Quoting an outdated manual makes absolutely NO SENSE.
