Case 580 Sl series 2 Fuel Gauge
Bill Byford
PostPosted: Mon Dec 11, 2017 12:11 pm    Post subject: Case 580 Sl series 2 Fuel Gauge Reply to specific post Reply with quote
Fuel gauge vibirates past empty to past full.Funny thing is let
idle few min. settles down to near normal with light vibiration.
Then with rpm, gauge goes crazy again.Drove across rough ground
to flex float but no help. Any help appreciated Bill
AJ.
PostPosted: Mon Dec 11, 2017 5:41 pm    Post subject: Re: Case 580 Sl series 2 Fuel Gauge Reply to specific post Reply with quote
Check the connections on the sender on top of the fuel tank,check that the wires are not chaffed and grounding out,check the tank mounting bolts are tight,remove the instrument control panel and see the multi plug is securely plugged in,I've had a similar problem with the alternator overcharging,the fuel gauge and techo were going crazy,a new alternator regulator sorted it,is the reading steady with the engine off.
AJ
